I want to make a choice between a 16x2 or a 20x4 LCD Display.
Therefore I wrote this
#ifndef LCD20
const uint8_t cols = 16; // 16 for 1602 display, 20 for 2004 display's
const uint8_t rows = 2; // 16 for 1602 display, 20 for 2004 display's
#elif
const uint8_t cols = 20; // 16 for 1602 display, 20 for 2004 display's
const uint8_t rows = 4;
#endif
but I get a compilation error:
Compilation error: #elif with no expression
What expression must #elif have to work??
Compiles OK for me with a Nano classic as the target board
Which Arduino board and IDE version are you using ?
Please post a complete sketch that illustrates the problem and post the full error message produced by that sketch
Given the snippet posted presumably #else
is a more reasonable choice.
#elif is short for "else if", so it expects an expression to evaluate for the "if" condition.
Try again with LCD20 defined, if that is not defined the compiler apparently never processes the #elif.
Try lihe this:
#ifndef LCD20
#elif LCDXX
#endif
Ref: Preprocessor directives | Microsoft Learn
As has been pointed out, the #elif is wrong and should probably be #else so no surprise that compilation fails under some circumstances
So changed the #elif To #else and it compiles correct, full code
#include <Wire.h>
#define LCD20 false // system uses 20X4 LCD else a 16x2 LCD display
#ifndef LCD20
#else
#endif
value = millis();
Serial.println(value);
Serial.println(rows);
void loop() {}
But now if #define LCD20 false or true in boht cases the value of rows = 4
MrY
9
In both cases of LCD20 being true or false, LCD20 is being defined. Therefore, the #else path is always taken.
Comment out the #define of LCD20, and then the #ifndef path should be taken.
So I have rewritten this section to
#if LCD20
#else
#endif
LiquidCrystal_I2C lcd(0x27, cols, rows); // set the LCD address to 0x27 for a 16 chars and 2 line display
Thnx for the input
system
Closed
11
