I have a project that up to this point has existed in several .ino files. This has worked for now, but I was interested in trying to move away from the alphabetical .ino compilation order, while at the same time learning more C++.
I tried to move the .ino files almost literally into .h and .cpp files, however the project .ino file encounters an issue when compiling. I created a small test project and searched a lot for answers, but so far have come up blank.
The Error
C:\Users\<path to my app data>\cc670oLO.ltrans0.ltrans.o: In function `loop':
E:\<path>\Projects\Arduino\potato-test\potato-test/potato-test.ino:8: undefined reference to `runPotato()'
I did see your post while searching, and as far as I can see I have done everything that you mentioned. Is there something more specific about what I am doing that seems wrong to you?
Apologies, those were errors in the original post; I have amended the code samples and paths.
Could it be that the compiler isn't seeing potato.cpp? Do the .h and .cpp have to be in the Arduino project root folder? I currently have them in the /test subfolder.
Edit:
I moved the .h and .cpp files into the root directory and they now compile correctly. @blh64 was right on the money.
To summarise:
All project files need to be in the root
Consts can be declared and defined in the .h
Variables must be declared extern in the .h and defined in the .cpp
FYI... you can put your .h files and .cpp files in a subfolder, but is has to be names 'src' and then the tool chain will still work. Other subfolder names will not
Of course, you have to adjust your include to be "src/potato.h"
