The following code is supposed to turn on a pin when “C1” is sent and turn off the pin when “C0” is sent. But it only works if I include the “Serial.println(“Hello”);” statement indicated in the comment.
What do I need to do to get the code to see that serial data is available without using that Serial.println statement?
int washerPin = 11;
// set the slaveSelectPins as outputs and turn to deselect (by setting HIGH):
pinMode (washerPin, OUTPUT);
// start serial port at 115,200 bits per second
void loop(void)
unsigned char cmd, value;
Serial.println("Hello"); // If I take this command out, it does not work
if(Serial.available()) {
cmd = Serial.read();
// If it's not a proper command, ignore it and wait for the next command
if(cmd != 'C') return;
value = Serial.read();
value = value - '0';
if (cmd == 'C') {
// If it's not a proper value (between 0 and 1), ignore it and wait for the next command
if(value < 0 || value > 1) return;
// got the command and value, now do the command
switch(value) {
case 0:
digitalWrite(washerPin, LOW);
case 1:
digitalWrite(washerPin, HIGH);
PS: I should note that I am running this on the Serial Monitor.
