[SOLVED] HC-05 command mode at 9600 bauds
Hello everyone !
I'm working on a project where I use the famous HC-05 Bluetooth module. As you may know the most common way to switch to command mode is to put KEY/EN pin at high and then power up the module. Using this procedure the module switch to command mode at 38400 bauds. But due to hardware limitation I'm not able to read feedback from the module at such a speed. That why I want to enter command mode at 9600 bauds. It is supposed to be possible by setting KEY/EN pin at high after powering up the module. In that case the module enter command mode with the user defined baud rate. So if we set the baudrate to 9600 before doing that it should work. As you can guess, it doesn't, it work fine as long as the module is configured with a baudrate of 38400 but a soon as I change the baudrate to 9600 I stop having response from the module. Does anybody already had this issue ?
Thank you for your responses :slight_smile:
In case you were wondering, I used a bad baudrate configuration command. I used AT+UART=9600,1,1 replace it with AT+UART=9600,0,0 and everything work fine
