I’ve written a class for detecting the button states for the power windows, door lock and latch buttons for my car.
It is set up for 2 button types:
Button Type 0: Door Locks/Latches
returns 3 States, Inactive(0), Pressed(1), Released(4)
Button Type 1: Power Windows
returns 5 States, Inactive(0), Pressed(1), Quick Press(2), Long Press Hold(3), Long Press Release(4)
It is working great except for one bug(so far).
When in state 3(long press hold) and I wiggle my finger on the button(causing bouncing I assume) it will return other states (1,2) randomly. I have tried several things to fix it, but have been unsuccessful in resolving the issue.
Hoping that one of the coding guru’s here can point out my mistake.
Button State Detection for Automotive Power Windows, Door Locks/Latches
Button Type 0: Door Lock/Latch
Detects 3 States
Detects 5 States
April 2016 by Les Hawkins
#define DEBUG true // Set to true to enable Serial Debug
#define Serial if (DEBUG)Serial // WARNING: Use only when Serial is used for Debugging only (THIS REMOVES Serial COMPLETLY!!!)
class PWButton
byte buttonPin;
byte buttonType;
byte buttonRead;
byte oldButtonRead;
byte buttonPressed;
byte buttonReleased;
byte buttonState;
unsigned long currentTime;
unsigned long startTime;
unsigned long debounceTime;
unsigned long quickPressThreshold;
public:
PWButton(byte pin, byte type, unsigned long bounce, unsigned long qpThresh)
buttonPin = pin;
pinMode (buttonPin, INPUT_PULLUP);
buttonType = type;
debounceTime = bounce;
quickPressThreshold = qpThresh;
byte check()
currentTime = millis();
buttonRead = digitalRead(buttonPin);
if (buttonRead != oldButtonRead)
oldButtonRead = buttonRead;
startTime = currentTime;
if (buttonPressed == 0 && buttonReleased == 0)
buttonState = 0; // Button Inactive
if (buttonRead == oldButtonRead && currentTime - startTime >= debounceTime)
if (buttonRead == LOW) // Button has been Pressed
buttonPressed = 1;
buttonState = 1;
else // Button has been Released
if (buttonPressed == 1)
buttonReleased = 1;
if (buttonType == 1) // Power Window Buttons
if (buttonState == 1 && buttonReleased == 1 && currentTime - startTime <= quickPressThreshold)
buttonState = 2; // Quick Press
buttonPressed = 0;
buttonReleased = 0;
if (buttonState == 1 && buttonReleased == 0 && currentTime - startTime > quickPressThreshold)
buttonState = 3; // Long Press Hold
if (buttonState == 3 && buttonReleased == 1 && currentTime - startTime > quickPressThreshold)
buttonState = 4; // Long Press Released
buttonPressed = 0;
buttonReleased = 0;
if (buttonType == 0) // Door Lock/Latch Buttons
if (buttonPressed == 1 && buttonReleased == 1)
buttonState = 4;
buttonPressed = 0;
buttonReleased = 0;
return buttonState; // 0= inactive, 1= pressed, 2= quick press, 3= long press held, 4= released
}; // END of Class
// BUTTON OBJECTS
PWButton pwbutton1 (9, 1, 40, 250); // ( pin(pin#), button Type(0 or 1), debounce time(millis), quick press threshold(millis) )
PWButton lockbutton1 (8, 0, 40, 0);
byte readbutton1;
byte readbutton2;
byte oldreadbutton1;
byte oldreadbutton2;
readbutton1 = pwbutton1.check();
if (readbutton1 != oldreadbutton1)
oldreadbutton1 = readbutton1;
Serial.println (readbutton1);
readbutton2 = lockbutton1.check();
if (readbutton2 != oldreadbutton2)
oldreadbutton2 = readbutton2;
Serial.println (readbutton2);
