#include <Wire.h>
int oilpres;
int temprF;
int temprFIAT;
const int fanOut = 2;
// Start i2c master
Wire.begin();
// initialize serial communication at 9600 bits per second:
pinMode(fanOut, OUTPUT);
// the loop routine runs over and over again forever:
tempCoolant(); // Calls on Coolant temp sensor that is in the Intake manifold.
Serial.println("CLT Temp:");
Serial.println(temprF);
//tempIAT(); // Calls on IAT sensor in Manifold
oilpressure(); // calls for OilPressure calculation
Serial.println("Oil Pressure:");
Serial.println(oilpres);
//fanControl(temprF); // controls fan
// batteryVoltage(); // 1m to 100k voltage divider 1k to ground, 1m to source, measure from middle to ADC.
// Wire.beginTransmission(9); // transmit to device #9
//Wire.write(oilp); // sends oil pressure
//Wire.write(temprF);
//Wire.endTransmission(); // stop transmitting
float tempCoolant()
float array[44] = {
// Voltage From Sensor on left // Corresponding Temprature on right ,
//You find this by using voltage divider forumla. Current set is for a 4.7k ohm R1 and R2 is your ACdelco Temp Sensor
2.429165 , 15 ,
2.137986 , 20 ,
1.864576 , 25 ,
1.613833 , 30 ,
1.38795 , 35 ,
1.188159 , 40,
1.013571 , 45,
0.8626761 ,50,
0.734253 , 55,
0.6246509 , 60 ,
0.5314699 ,65,
0.4536661 ,70,
0.3876349 ,75,
0.3317441 ,80,
0.286803 ,85 ,
0.2446477 ,90,
0.2110208 ,95,
0.1824518 ,100,
0.1582331 ,105,
0.1376963 ,110,
0.1201279 ,115,
0.1050845 ,120,
// read the input on analog pin 0:
float sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.00 / 1023.0); // change for differant base voltage
float tempr ;
if ( voltage >= array[0] )
tempr = array[1] ;
else if ( voltage <= array[42] )
tempr = array[43] ;
for ( int i = 1 ; i < 44 ; i++ )
int ii = 2 * i ;
if ( voltage <= array[ii] && voltage >= array[ii + 2] )
tempr = array[ii + 1] + ( (array[ii + 3] - array[ii + 1]) * ( voltage - array[ii] ) / ( array[ii + 2] - array[ii] )) ;
break ;
temprF = tempr * 1.8 + 32;
return temprF;
float oilpressure()
float array[12] = {
//You find this by using voltage divider forumla. Current set is for a 330 ohm R1 and R2 is your VDO Oil Pressure sensor
2.105263 , 0.1,
1.944444 , 14.5,
1.764706 , 29,
1.5625 , 43.5,
1.071429 , 72.5,
0.4141189 , 100,
// read the input on analog pin 1:
float sensorValue = analogRead(A6);
//Serial.println(sensorValue);
float oilp;
if (voltage >= array[0])
oilp = array[1];
else if (voltage <= array[10])
oilp = array[11];
for (int i = 1; i < 12; i++)
int ii = 2 * i;
if (voltage <= array[ii] && voltage >= array[ii + 2])
oilp = array[ii + 1] + ((array[ii + 3] - array[ii + 1]) * (voltage - array[ii]) / (array[ii + 2] - array[ii]));
int oilpres = oilp;
return oilpres;
Thats the code. SOrry, didnt know pastebin was hated here…
