I am trying to learn how to use/implement a watchdog timer. I was messing around with writing a test sketch and apparently bricked two MKR NB 1500 boards. I say I bricked them because after uploading the following sketch, I am getting a USB device error ("USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it.") and neither board is showing up as connected in the Arduino IDE under the Tools > Port.
Here is the code:
#include <Arduino.h>
#include <MKRNB.h>
#include <ArduinoLowPower.h>
#include <Adafruit_SleepyDog.h>
Serial.println("Serial monitor begin");
//WDT Setup
int wdtTimeout = Watchdog.enable(5000);
Serial.print("WDT enabled with max timeout of ");
Serial.print(wdtTimeout, DEC);
Serial.println("ms");
Serial.println("Now I'm in the loop");
Watchdog.sleep(2000);
Watchdog.reset();
Other details/comments:
- Windows 10
- Both boards were previously working fine.
- I had previously uploaded a slightly different version of this same sketch which left out the last two lines of code (the watchdog.sleep and watchdog.reset) and was working fine (as in the board kept resetting since I wasn't resetting the wdt). It only appears to have bricked the board after I made this change. I have no idea why this code would have bricked a board, but both boards were working fine until I uploaded this exact code.
- I initially wrote this code in VS Code & PlatformIO. After bricking the first board I copied the code into a new sketch in Arduino IDE and uploaded to the second board and had same results.
- I know there are several library references that aren't needed in this sketch, they were copied from a previous sketch and I lazily didn't delete the ones that aren't being used in this sketch. Also noticed that I have the Arduino library twice.
- I've tried different USB cables & ports
- Tried restarting the computer
Any suggestions or ideas welcome! Thanks!
