Hi all, I am having problems trying to figure this all out. I do not understand the terminology of Arduino.
I purchased my GPS receiver from GPS_Module_With_Enclosure__SKU_TEL0094_-DFRobot
I have wired it to:
GPS module ==> Arduino
GND ==> GND
TX ==> Digital pin (D4)
RX ==> Digital pin (D3)
Vcc ==> 5V
I have tried this code:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
const char UBLOX_INIT[] PROGMEM = {
0xB5, 0x62, 0x06, 0x08, 0x06, 0x00, 0x64, 0x00, 0x01, 0x00, 0x01, 0x00, 0x7A, 0x12, //(10Hz)
Serial.begin(57600);//57600
ss.begin(GPSBaud);
for (int i = 0; i < sizeof(UBLOX_INIT); i++) {
ss.write( pgm_read_byte(UBLOX_INIT + i) );
delay(5);
Serial.println(F("DeviceExample.ino"));
Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
on the serial monitor I see "No GPS detected: check wiring."
if i put my scope on pin D4 I do see a signal.
This is the pin out referance I am going by:
can anyone see what I am doing wrong?
Thanks
Rick
