I am using this code to get the addresses of the sensors.
// Programa : Scan DS18B20
// Alterações : Arduino e Cia
// Este programa procura pelos sensores no circuito e mostra o valor
// do endereço físico de cada sensor no Serial Monitor
#include <OneWire.h>
// Conecte o pino central dos sensores ao pino 10 do Arduino
OneWire ds(2);
void setup(void)
discoverOneWireDevices();
void discoverOneWireDevices(void)
byte i;
byte present = 0;
byte data[12];
byte addr[8];
Serial.print("Procurando dispositivos DS18B20...\n\r");
while(ds.search(addr))
Serial.print("\n\rEncontrado sensor \'DS18B20\' com endereco:\n\r");
for( i = 0; i < 8; i++)
Serial.print("0x");
if (addr[i] < 16)
Serial.print('0');
Serial.print(addr[i], HEX);
if (i < 7)
Serial.print(", ");
if ( OneWire::crc8( addr, 7) != addr[7])
Serial.print("CRC nao e valido!\n");
return;
Serial.print("\n\r\n\rFinal da verificacao.\r\n");
ds.reset_search();
return;
void loop(void)
// Loop Vazio
This is the return.
Encontrado sensor 'DS18B20' com endereco:
0x28, 0xAC, 0x0A, 0x38, 0x05, 0x00, 0x00, 0xE3
0x28, 0x5D, 0x67, 0x38, 0x05, 0x00, 0x00, 0x5B
0x28, 0xFD, 0xF5, 0x2D, 0x07, 0x00, 0x00, 0xC5
0x28, 0x33, 0x6B, 0x38, 0x05, 0x00, 0x00, 0xAA
0x28, 0xFF, 0x7C, 0x61, 0x92, 0x15, 0x01, 0x31
0x28, 0xFF, 0x65, 0xA1, 0x92, 0x15, 0x01, 0x87
0x28, 0xFF, 0x55, 0x65, 0x92, 0x15, 0x01, 0x34
0x28, 0xFF, 0xD5, 0x64, 0x92, 0x15, 0x01, 0x70
0x28, 0xFF, 0xB5, 0x6E, 0x92, 0x15, 0x01, 0x7A
My question...
That determines sequence is used? Hex determines the sequence?
Even if I change the place of sensor, the sequence remains the same.
Thanks for all.
