[Solved] How can I check if a space is in a String
Dear All,
I am getting the answer of a AT command
if(Serial1.available() > 0)
        if(x < BUFFERSIZE-1) // Do not fill the buffer more the it size
           buffer[x] = Serial1.read();
           if(buffer[x] != 0x040)
             Serial.prinln(F("OK"));
             Serial.println(F("Replace"));
If there a space, I need to replace it with a -
It always display OK
I tryed several things
if(buffer[x] != '0x040')
if(buffer[x] != 0x20)
if(buffer[x] != '0x20')
if(buffer[x] != 32)
if(buffer[x] != "") // Dont compile
if(buffer[x] != '') // Dont compile
if(buffer[x] != " ") // Dont compile
if(buffer[x] != ' ') // Dont compile
How can I simply make false when there is a space
for exemple:
+CENG: 1 (Space bedore 1)
How can I simply make false when there is a space for exemple:
Post all of your code correctly. For all we know, buffer is an array of floats, which explains why the code does not compile.
Oups sorry, It's done
Sorry for code display, I corrected it.
When I compare
if(buffer[x] == '\n')
or
if(buffer[x] == '\r')
It compile. So how can I do the same with a space?
if(buffer[x] == ' ')
If that doesn't compile, do not bother posting another snippet. Post ALL of your code and the EXACT error message.
If you capture your String, you probably use a String function similar to below.
          if(readString.contains(" ")) { //test for character in string
            readString.replace(' ', '#');
http://arduino.cc/en/Tutorial/StringReplace
Hello,
if Serial.read()
return
+CENG: 1.1
and then
buffer[x]=Serial.read();
Serial.println(buffer[x]);
will display:
C
E
N
G
[Space]
1
1
Then (I wrote [Space] because I do not what to write
 if(buffer[x] != [Space])
Should display
OK for +
OK for C
OK for E
OK for N
OK for G
OK for :
Replace for the space
OK for 1
OK for .
OK for 1
My problem, it always display OK excepted when it does not compile because of ‘’ or “”
My worrie is which is the correct syntax to compare a Space.
To compare \n, I can write
 if(buffer[x] != '\n')
To be sincerely with you, there were another small bug, which did not help me and I finally found my needed answer
Here is the solution
char comp[2] = {' ','\0'};
if(buffer[x] != comp[0])
       start_record = true;
       Serial.println(F("Space"))
And I later tried and it works (finally)
So this was the answer I needed
Cheers
if
Serial.read()
return
+CENG: 1.1
It doesn't. Serial.read() reads ONE byte.
This is nonsense.
More nonsense, because all you have posted is snippets.
Take your snippets to http://snippets-r-us.com, and do not come back here until you can post ALL of your code.
Dear Pauls,
My code is on my first post and re pasted in my last reply
This I know, and it's what I explain in my last reply
will display:
+ C E N G : [Space] 1 . 1
if(buffer[x] != [Space]) //I wrote [Space] because I do not what to write, and this my question
Should display
OK for + OK for C OK for E OK for N OK for G OK for : Replace for the space OK for 1 OK for . OK for 1
But as I stated, my problem is solved and it's works
If it does not make nosens, could you show an exemple or a better solution? To simply answer to that question
if(buffer[x] != 0x20) // where buffer[x] is egal to a space
