[solved] How can I have a \n for JSON Line
Hello
I am writing a example file and my goal is to save some measurement into a jsonl file
Example:
{"mod":"demo","date":"24-07-05","sensors":[{"temp":"22","altitude":"454"}]}
{"mod":"demo","date":"24-07-06","sensors":[{"temp":"23","altitude":"454"}]}
{"mod":"demo","date":"24-07-07","sensors":[{"temp":"24","altitude":"454"}]}
{"mod":"demo","date":"24-07-08","sensors":[{"temp":"23","altitude":"454"}]}
selon JSON Line, each
must be on one line. So at the end of the entry, we need to have a \n
If we look at my script here,
  1. I open the file
  2. I serialized my object and I save the string directly into my file. I followed that example (See "write to a file")
  3. Then I close my file.
If now I look at my file, each entry follow the previous entry. All is in one line.
File sd_log;
sd_log = sd.open(fileName, O_RDWR | O_CREAT | O_AT_END);      // Open the file log.jsonl
serializeJson(jdoc,sd_log);                                   // serialize and write te directly to the file
sd_log.close();
My question, is there a way to tell serializejson() to append a \n ?
Thanks
OK, forget this topics.
Simply add sd_log.println();
File sd_log;
sd_log.println();
sd_log.close();
That’s adding both CR ‘\r’ and LF ‘\n’
If you only want LF then you can just do sd_log.write('\n');
EDIT: NOT SUITABLE FOR A JSON LINES FORMAT
Note that instead of serializeJson() you could also use serializeJsonPretty() which will add line breaks and spaces etc to make you JSON look nice
JSON Lines is a distinct record-per-line format, sort of like CSV, but with more flexibility and a lot more quotation marks.
  • no difference between \r\n and \n -- extra whitespace outside of a data value is ignored in all cases
  • pretty-printing would change the meaning
thanks I had missed the small l at the end of
Hello
Thansk for your replies. This make sense:
sd_log.write('\n');
Thanks
