The problem went away when I changed the RF24 library. Instead of using Maniacbug's RF24, I used G. Copeland's fork of RF24.
Just for kicks, I deleted the RF24 library and replaced it with the latest from maniacbug's github. The problem reappeared. Went back to the Copeland forked RF24, problem went away. And that was just with recompiling and uploading on the sender Arduino.
I don't understand why. But it fixed my issue.
I ran into an odd issue with an example sketch for the nRF24L01. It's a simple sender/receiver sketch. It works fine as is. I see the data coming from sender to receiver. But, if I add a delay(xx) before sending, the receiver never sees the packet.
Here's the code. Peter made a great point below, so I modified the sender with a millis counter, to give me an idea of how fast the sender is actually sending and if it's retrying. I tried adjusting the delay ms and found out something interesting.
delay(10) or less: receiver scrolls fast, more than 20 transmissions per second, faster than I can count certainly.
delay(11): receiver now only gets one transmission every 2 or 3 seconds. It's inconsistent, but I see it scroll at least
delay(12) or greater: major issues with transmission. No transmissions received after 1 minute.
These delays are only ms apart. And I kept the setup the same (no touching or moving the radios) during these tests. After testing higher delay() values, I went to down to delay(5) and the receiver started scrolling through the data again. So, there's something weird going on, and I've done as much as I can think to do not to shoot myself in the foot.
Sender. If I comment out the delay(xx), it works fine. Or make the delay < 10ms, it works.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 8
#define CSN_PIN 7
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
RF24 radio(CE_PIN, CSN_PIN);
typedef struct
int DevID;
float DevVal;
int DevSig;
} twoInts;
twoInts SensorNode;
int mytime = 0;
void setup() /****** SETUP: RUNS ONCE ******/
radio.begin();
radio.openWritingPipe(pipe);
mytime = millis();
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
int timeleft = millis() - mytime;
delay(12); // <<<---------------- change delay to see what happens
SensorNode.DevID = 3;
SensorNode.DevVal = timeleft;
radio.write( &SensorNode, sizeof(SensorNode) );
Serial.println("done sending");
if (timeleft > 6000)
mytime = millis();
Receiver...this doesn't matter very much since it's not causing the problem, but just in case I'm wrong I'm including it.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#define CE_PIN 8
#define CSN_PIN 7
typedef struct
int DevID;
float DevVal;
int DevSig;
} twoInts;
twoInts SensorNode;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
Serial.println("Nrf24L01 Receiver Starting");
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();;
if ( radio.available() )
// Read the data payload until we've received everything
bool done = false;
while (!done)
// Fetch the data payload
done = radio.read( &SensorNode, sizeof(SensorNode) );
Serial.print("X = ");
Serial.print(SensorNode.DevID);
Serial.print(" Y = ");
Serial.println(SensorNode.DevVal);
//Serial.println("No radio available");
