Hello everyone!
I am new to this and I am doing my first project and I encounter the problem of not having anything to write at all! :’(
Anyways, I am doing something like this: I want pot1 to set some number (0-1023) and pot2 to be an adjustment pot and set number 512 (middle position of the pot2) as its zero(origin). Print pot1 and pot2 values to the serial monitor.
So if pot1 is at 0, and pot2 is also at 512, LCD output will be 0.
If pot1 is at 800, and pot2 is at 512, still LCD output is at 800.
If pot1 is at 800, and pot2 is at 812, LCD output is at 1100 (from 800+300).
If pot1 is at 800 and pot2 is at 212, LCD output will be 500.
If pot1 is at 100 and pot2 is at 212, LCD output is at -200.
If pot1 is at 0, and pot2 is at 0, LCD will output -512.
So basically, I want to shift origin of numbers. Pot1 is the number and pot2 is the adjuster. How should I do this?
I appreciate your guidance my gurus. Thank you all.
Here is my code that I can’t even finish:
#include <LiquidCrystal.h> //Load Liquid Crystal library
LiquidCrystal lcd(10, 9, 5, 4, 3, 2); //Create Liquid Crystal object as LCD
int pot1= A0; //Declare variable and set to A0 (from 0 to 1023)
int pot2= A1; //Declare variable and set to A1 (from 0 to 1023)
int potValue1; //Declare variable to store pot1 value
int potValue2; //Declare variable to store pot2 value
int adjustValue; //New value after adjustment
pinMode(pot1, INPUT); //Set as input
pinMode(pot2, INPUT); //Set as input
Serial.begin(9600); //Start serial com at baud rate 9600
lcd.begin(16,2); //Start LCD 16x2
lcd.setCursor(0,0); //Start printing at 0,0
lcd.print("Value: "); //Print message
potValue1 = analogRead(pot1); //Store analog read to potValue1
potValue2 = analogRead(pot2); //Store analog read to potValue1
Serial.print(potValue1); //Print potValue1 to serial monitor at left side
Serial.print(" | "); //Print space in between potValue1 and potValue2
Serial.println(potValue2); //Print potValue2 to serial monitor at right side
* What should I write here?
lcd.setCursor(0,1); //Start printing at 0,1
lcd.print(adjustValue); //Print new value after adjustment
delay(250);
moderator added some newlines.
