[Solved] how i can read a php page?
HI guys!
i have a virtual server where i create a string that i need read with my arduino.
I made a php page and this write the string correctly when you access with a broser.
it is the php page
<?php
$fp = fopen("cambiorelojes.txt", "r");
$linea = fgets($fp);
fclose($fp);
echo "$linea";
I change the webclient example
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "www.domain.com";    // name address for Google (using DNS)
IPAddress ip(192,168,1,38);
EthernetClient client;
   while (!Serial) {
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  Serial.println("connecting...");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.println("GET www.domain.com/relojes/leercambio.php");
    client.println("Host: www.domain.com");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    while(true);
And it is the error.
connecting…
connected
400 Bad Request
Bad Request
Your browser sent a request that this server could not understand.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
disconnecting.
Thanks
No domain name in the GET line, just the document name.
    client.println("GET /relojes/leercambio.php");
Hi surfertim! I try your code but no found. I've gotten it to work change this line and write this
client.println("GET http://www.arduacuario.com/relojes/leercambio.php");
Thanks once again
