[SOLVED] How to add space and - characters to the array with large number ?
I need to display the numbers from -32 to 0
I have found this good array with the numbers 0-9 but how to add the - and space characters ?
fontdatatype Shruti_Bold_num_48x70[4204] PROGMEM={
0x30,0x46,0x30,0x0A,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x03,0xFF,0xFF,0x80,0x00,0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x00,0x1F,0xFF,0xFF,0xF0,0x00,0x00,0x3F,0xFF,0xFF,0xF8,0x00,0x00,0x7F,0xFF,0xFF,0xFC,0x00,0x00,0xFF,0xFF,0xFF,0xFE,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x00,0x03,0xFF,0xF8,0x1F,0xFF,0x80,0x03,0xFF,0xC0,0x07,0xFF,0x80,0x07,0xFF,0x80,0x03,0xFF,0xC0,0x07,0xFF,0x00,0x01,0xFF,0xC0,0x0F,0xFF,0x00,0x00,0xFF,0xE0,0x0F,0xFE,0x00,0x00,0xFF,0xE0,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x3F,0xF8,0x1F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x1F,0xFC,0x3F,0xF0,0x00,0x00,0x1F,0xFC,0x3F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x7F,0xF0,0x00,0x00,0x1F,0xFC,0x3F,0xF0,0x00,0x00,0x1F,0xFC,0x3F,0xF0,0x00,0x00,0x1F,0xFC,0x3F,0xF8,0x00,0x00,0x1F,0xFC,0x3F,0xF8,0x00,0x00,0x1F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x1F,0xF8,0x00,0x00,0x3F,0xF8,0x1F,0xFC,0x00,0x00,0x3F,0xF8,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x0F,0xFE,0x00,0x00,0xFF,0xE0,0x0F,0xFF,0x00,0x00,0xFF,0xE0,0x07,0xFF,0x00,0x01,0xFF,0xC0,0x07,0xFF,0x80,0x03,0xFF,0xC0,0x03,0xFF,0xC0,0x07,0xFF,0x80,0x01,0xFF,0xF8,0x3F,0xFF,0x80,0x01,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x7F,0xFF,0xFF,0xFC,0x00,0x00,0x3F,0xFF,0xFF,0xF8,0x00,0x00,0x1F,0xFF,0xFF,0xF0,0x00,0x00,0x07,0xFF,0xFF,0xE0,0x00,0x00,0x01,0xFF,0xFF,0x00,0x00,0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  // 0
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x03,0xFF,0xFF,0x80,0x00,0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x00,0x1F,0xFF,0xFF,0xF8,0x00,0x00,0x7F,0xFF,0xFF,0xFC,0x00,0x00,0xFF,0xFF,0xFF,0xFE,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x80,0x03,0xFF,0xF0,0x1F,0xFF,0xC0,0x07,0xFF,0xC0,0x07,0xFF,0xC0,0x07,0xFF,0x80,0x01,0xFF,0xE0,0x0F,0xFF,0x00,0x00,0xFF,0xE0,0x0F,0xFE,0x00,0x00,0xFF,0xF0,0x1F,0xFE,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x3F,0xF8,0x1F,0xFC,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x3F,0xF8,0x3F,0xF8,0x00,0x00,0x1F,0xFC,0x3F,0xF8,0x00,0x00,0x1F,0xFC,0x3F,0xF8,0x00,0x00,0x1F,0xFC,0x3F,0xF8,0x00,0x00,0x0F,0xFC,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x0F,0xFE,0x3F,0xF8,0x00,0x00,0x07,0xFE,0x3F,0xFC,0x00,0x00,0x07,0xFE,0x1F,0xFC,0x00,0x00,0x07,0xFE,0x1F,0xFE,0x00,0x00,0x0F,0xFE,0x1F,0xFE,0x00,0x00,0x3F,0xFE,0x0F,0xFF,0x00,0x00,0x7F,0xFE,0x0F,0xFF,0x80,0x00,0xFF,0xFE,0x07,0xFF,0xE0,0x07,0xFF,0xFE,0x07,0xFF,0xFC,0x3F,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xEF,0xFE,0x00,0x7F,0xFF,0xFF,0xCF,0xFE,0x00,0x3F,0xFF,0xFF,0x8F,0xFE,0x00,0x0F,0xFF,0xFE,0x0F,0xFE,0x00,0x03,0xFF,0xF8,0x0F,0xFE,0x00,0x00,0x7F,0xC0,0x0F,0xFE,0x00,0x00,0x00,0x00,0x0F,0xFC,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0x00,0x3F,0xF8,0x1F,0xF8,0x00,0x00,0x3F,0xF8,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0x7F,0xF0,0x1F,0xFC,0x00,0x00,0xFF,0xF0,0x1F,0xFE,0x00,0x01,0xFF,0xE0,0x0F,0xFE,0x00,0x01,0xFF,0xE0,0x0F,0xFF,0x00,0x07,0xFF,0xC0,0x07,0xFF,0x80,0x0F,0xFF,0xC0,0x07,0xFF,0xF0,0x3F,0xFF,0x80,0x03,0xFF,0xFF,0xFF,0xFF,0x00,0x01,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0xFF,0xFF,0xFF,0xFC,0x00,0x00,0x7F,0xFF,0xFF,0xF8,0x00,0x00,0x3F,0xFF,0xFF,0xF0,0x00,0x00,0x0F,0xFF,0xFF,0xC0,0x00,0x00,0x03,0xFF,0xFF,0x00,0x00,0x00,0x00,0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  // 9
Hello Ciuffoly
Welcome to the Arduino fora.
Before you do anything else please read eneral guidance
And
How to use this forum
Especially item #7 on posting code.
It would also help if you explained what you are trying to do, it is not at all clear from your question.
Thank you.
It "looks" as if you have a font intended for UTFT.
You either create a font that starts with 0x20 (space) and ends with 0x39 ('9') and includes 0x2D ('-')
Or you create a font that starts with 0x2D and ends with 0x39. And simply move the cursor for a space.
As Mr Bebbington has suggested, read the Forum guidance e.g. paste your code into code windows
And post links to your hardware e.g. Ebay adverts
The UTFT site has several fonts here
David.
yes, I can add 2 lines in the array with the bytes for the space and - but how to tell to use it
0x30,0x46,0x30,0x0A,   <<< need to chaneg only 0x0A with 0x0B ???
//0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,   // space
Please say what library, what hardware, what sketch code, ...
I suspect that your sketch is too big to paste. So you should attach the file. Or post a link to code in a repository like GitHub.
Then you will get an appropriate reply.
David.
Solved
fontdatatype Shruti_Bold_num_48x70[5044] PROGMEM={
0x30,0x46,0x30,0x0B,
.... 0 to 9 lines
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00   // -
int num = level;
        int pos = 0, neg = 0;
        int i, k, j;
        if (num < 0)
            num = -num;
            neg = 1;
        for (i = 0; num > 0 ; i++ )
                buf[i] = 48 + (num % 10);
                num=(num-(num % 10))/10;
        buf[i] = '\0';
        myGLCD.setFont((unsigned char *)Shruti_Bold_num_48x70);
        for (k = 4; k > (i + neg); k--)
                if (num == 0 && k == 1)
                        myGLCD.printChar('0', 100 + pos * 50, 100);
                        myGLCD.printChar(':', 100 + pos * 50, 100);
                pos++;
        if (neg)
               myGLCD.printChar(';', 100 + pos * 50, 100);
               pos++;
        for (j = i - 1; j >= 0;  j--)
                myGLCD.printChar( buf[j], 100 + pos * 50, 100);
                pos++;
