SOLVED How To run DHT11 with U8g
I have a question for the knowledgeable members of the forum , with regards to Temp, Humi, and Press.
Question 1. I have a 12864J display running U8glib, DS3231, DHT11, showing time and date but am having trouble to get the DHT11 to show temp C/F on the display, I have looked at the tutorial on U8g and am having trouble understanding the draw.str function to show temp C/F.
Have includes the program for Q1,
#include "U8glib.h"
#include <DS1307.h>
#include "DHT.h"
U8GLIB_ST7920_128X64_4X u8g(4,3,2); //12864J display
//U8GLIB_ST7920_128X64_1X u8g(10); //12864ZW display
DS1307 rtc(A4, A5);
#define DHTPIN 7
#define DHTTYPE DHT11
 float t=0;
 int a,b;
 int tempC, rh, tempF, tempI;
 byte zero = 0x00;
DHT dht(DHTPIN,DHTTYPE);
  // flip screen, if required
   //u8g.setRot180();
   // Set the clock to run-mode
  rtc.halt(false);
  // The following lines can be commented out to use the values already stored in the DS1307
  //rtc.setDOW(WEDNESDAY);        // Set Day-of-Week to SUNDAY
  //rtc.setTime(12, 0, 0);     // Set the time to 12:00:00 (24hr format)
  //rtc.setDate(3, 10, 2010);   // Set the date to October 3th, 2010
  /* Start of a picture loop */
  u8g.firstPage();
  /* Keep looping until finished drawing screen */
  do
    /* Set the font */
    u8g.setFont(u8g_font_courB14);
    u8g.drawStr( 22, 22, rtc.getTimeStr());
    u8g.setFont(u8g_font_6x10);
    u8g.drawStr( 50, 35, rtc.getDateStr());
    u8g.drawStr( 23, 35, rtc.getDOWStr(FORMAT_SHORT));
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float f = dht.readTemperature(true);
  float i = dht.computeHeatIndex(f, h); //Heat Index
  tempF = (int)(tempC * 9.0 / 5.0) + 32.0;
  tempC = (int)t;
  tempI = (int)i;
  rh   = (int)h;
    /* Draw a simple border */
    u8g.drawFrame(3,3,121,58);
    u8g.drawStr( 15, 45, "Temp");
    //u8g.drawStr( 45, 45, ); //Temp C here
    u8g.drawStr( 60, 45, "C");
    //u8g.drawStr( 70, 45, ); //Temp F here
    u8g.drawStr( 90, 45, "F");
  }while(u8g.nextPage());
Hope someone can help.
How to part 2 has been re posted
Question 2.
Can you maybe make two posts about this? This is all a bit of a mouthful.
How can the second question be removed so that it can be re posted.
You edit your question. Cut the second question from it (Edit menu in your browser). Then make a new question and paste it in.
JQuinn:
Question 2. How can you get a DS3231, BMP180, running at 3.3v to work together on the I2C bus on a graphic display using either GLCD/UTFT/U8g, both work singley on a graphic display but when you add the bmp program to the time display, time is stopped but is still displayed and the bmp still functions normally.
I have a similar setup, running on a 20x4 LCD with the DS and BMP working together.
I have Googled the web and looked on the forum for answers but no information has been found, there is info on DS’s , BMP’s and I2C bus singley but not working together.
There should be no specific issue here. I would first determine if you're able to read the values correctly (eg, writing to serial). I've had spooky problems with BMP180's...
