[SOLVED] How to set bigger value for potentiometer and stable it?
Hi all,
May I know how to set a bigger value and make it stable? This is the potentiometer that im using...
And here is the code:
PotPosition_value = analogRead(PotPin); //Read and save analog value from potentiometer
PotPosition_value = map(analogRead(PotPosition_value), 0, 1023, 1500, 8500);
Serial.println(PotPosition_value);
I managed to get the max value. however, the value is unstable:
16:50:01.129 -> 7439
16:50:01.213 -> 7282
16:50:01.281 -> 8500
Thanks in advance!
This code is not correct - the second line is doing an analogRead() on an invalid I/O pin
PotPosition_value = map(analogRead(PotPosition_value), 0, 1023, 1500, 8500); //This is for Launch use only
I think it should be
PotPosition_value = map(PotPosition_value, 0, 1023, 1500, 8500); //This is for Launch use only
And it would be easier to debug if you separate the mapped value from the original value - like this
MappedPosition_value = map(PotPosition_value, 0, 1023, 1500, 8500); //This is for Launch use only
Serial.println(MappedPosition_value);
...R
Robin2:
...R
Thank you!! Robin! :slight_smile:
