I have been trawling the site, but to no avail. Maybe I'm searching the wrong thing.
Anyway, I want to take 8 inputs and put theses into a byte.
The inputs will be from different ports, so i cannot just read a port.
Input 1 to go into lsb or bit 0
I can do a digitalRead(pinX) but how do I get input information into a specific bit in the byte
Cheers and happy new year
K
system
2
The bitWrite() function comes to mind.
Primo. Thanks a lot as I hadn't seen those byte instructions.
K
system
4
fiddler:
Here's the code I would write for that:
unsigned char bitPorts[] = {
1, 3, 5, 7, 9, 2, 4, 6 // or whatever -- first is LSB, ... last one is MSB
unsigned char portsToByte() {
unsigned char ret = 0;
unsigned char bval = 1;
for (int i = 0; i < 8; ++i) {
if (digitalRead(bitPorts[i]) != 0) {
ret = ret | bval;
bval = bval << 1;
return ret;
While this currently does work since LOW is currently defined as zero,
To be compliant with the digitalRead() api it should be:
  if (digitalRead(bitPorts[i]) != LOW) {
as the API does not guarantee that LOW is 0.
--- bill
