In order to upload the miniEngine1program by Airic Lenz on an Arduino UNO, I have to re-install IDE 1.0.6, if I try to do this with a more recent IDE I have several error messages. I suppose it's due to some evolution of coding. Is there any systematic and simple way to upgrade this code ? I don't have any coding skills.
Since I can't upload here the program folder (too recent member) I just copy the first file out of 9 :
See www.openmoco.org for more information
2015 Airic Lenz, C.A. Church
The 1st version of this code, dealing with core functionalities,
was heavily inspired by the OpenMoCo Engine by C.A. Church
and is basically based on it. Thank you for your great work!
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
// Max sketch size size for 32k Arduinos: 28,672 bytes = 0x7000
#include "Wire.h"
#include "LiquidCrystal.h"
#include "EEPROM.h"
#include <avr/pgmspace.h>
#include <RTClib.h> // See https://github.com/jcw/rtclib
// #include <MemoryFree.h> // See http://www.arduino.cc/playground/Code/AvailableMemory
// Version of the software
#define VERSION 1
#define SUBVERSION 3
// Arduino pins
// pin to tell the motor drivers to go to sleep
#define MOTOR_SLEEP_PIN 2
#define MOTOR_STEP_PIN 12
#define MOTOR_DIR_PIN 13
// shutter and focus connections
#define CAMERA_PIN 3
#define FOCUS_PIN 11
// pin for LCD backlight
#define LCD_BACKLIGHT_PIN 10
// pin for reaing analog key input
#define LCD_KEY_PIN A0
// limit switches for stopping the program
// one for each side of teh dolly
#define LIMIT_SWITCH_PIN_1 A2
#define LIMIT_SWITCH_PIN_2 A3
// General action status flags:
// B0 = operating mode (0 = shoot-move-shoot; 1 = continuous)
// B1 = camera focussing
// B2 = start cycle immediately
// B3 = camera shooting
// B4 = program running
// B5 = camera post exposure
// B6 = motor slot open
// B7 = motor post delay is active
byte action_status = B0;
// the time we started with an action (focussing, exposure, post delay)
unsigned long action_start_time;
// Camera settings
// cycle length of the whole cycle in half seconds (4 * 0.5 = 2 seconds)
unsigned int cycle_length = 4;
// camera shoot counter
unsigned int camera_shoot_count = 0;
// the focus line will be risen before the exposure is done (in milliseconds)
unsigned int camera_focus_time = 0;
// the time we want to expose our pictures (in milliseconds)
unsigned int camera_exp_time = 100;
// time after exposure before the motor is moved (in milliseconds)
unsigned int camera_exp_post = 200;
// the maximum amount of shots to do (0 = unlimited)
unsigned int camera_shot_max = 0;
// defines the camera behaviour
// B0 = Focus line high or low while exposing
// B1 =
// B2 =
// B3 =
// B4 =
// B5 =
// B6 =
// B7 =
byte camera_status = B0;
// Motor settings
// motor ramping types
#define RAMPING_LINEAR 0
#define RAMPING_ATANGENS 1
#define RAMPING_SINUS 2
// used motor ramping
#define MOTOR_RAMP_TYPE RAMPING_ATANGENS // see the definitions just before this line for possible choices.
// acceleration and decelleration time (in steps)
unsigned int motor_ramp = 500;
// total number of pulses for move (1600 steps per rev)
unsigned long motor_steps = 0;
// number of maximum steps the motor is allowed to do (0 = unlimited)
unsigned long motor_steps_max = 0; // 0 = no limit
// delay after motor movement
unsigned int motor_post = 0;
// maximum delay in microsecond (delay between steps at minimum
// speed of the motor (start and endphase)).
unsigned long motor_step_delay_max = 15000;
// minimum delay in microseconds (delay between steps at maximum speed of the motor)
unsigned long motor_step_delay_min = 100;
// the amount of steps done away from the defined home position
// clockwise = direction bit low (positive count)
// anti-clockwise = direction bit high (negative count)
long home_steps = 0;
// General Motor status flags:
// B0 = sleep on / off (the pin has to be set inverse --> sleep on = pin low)
// B1 = limit switches on / off
// B2 =
// B3 =
// B4 = motor direction
// B5 =
// B6 =
// B7 =
byte motor_status = B11000000;
// the time we started the program
unsigned long program_start_time;
// Display
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// Timed-Programs (RTC) status flags:
// B0 = timed-program running
// B1 = active programs in the future
// B2 =
// B3 =
// B4 =
// B5 =
// B6 =
// B7 =
byte program_status = B0;
// the max number of programs available
#define program_amount 20
// the program that is curently edited, 255 = no program is editet
byte current_program = 255;
// the program that is curently running
byte running_program = 255;
// the number of programs we have defined;
byte program_count = 0;
// day flags of the programs
// B0 monday
// B1 tuesday
// B2 wednesday
// B3 thursday
// B4 friday
// B5 saturday
// B6 sunday
// B7 use weekdays (low = use single date)
byte program_weekdays[program_amount];
// start date and time of the program
DateTime program_datetime[program_amount];
// program duration in minutes
unsigned int program_duration[program_amount];
// other flags of the programs
// B0 enabled / disabled
// B1 move back to home
// B2
// B3
// B4
// B5
// B6
// B7
byte program_flag[program_amount];
// content of the menu (we initialize the array with some items -
// fitting the longest possible menu - have a look at mE_program
// to check the program amount!!! - all programs will be listed in
// one menu - the longest regular menu is 7 items long)
char lines[20][17];
// User interface
// Strings of our menu.
// This is done to store the strings in in the program flash.
// If given like this: "some string", the strings would be placed in
// the RAM.
prog_char string_0 [] PROGMEM = "On ";
prog_char string_1 [] PROGMEM = "Off";
prog_char string_2 [] PROGMEM = "CW ";
prog_char string_3 [] PROGMEM = "CCW";
prog_char string_4 [] PROGMEM = "Stp:";
prog_char string_5 [] PROGMEM = "D:";
prog_char string_6 [] PROGMEM = "Program started.";
prog_char string_7 [] PROGMEM = "Program stopped.";
prog_char string_8 [] PROGMEM = "enabled";
prog_char string_9 [] PROGMEM = "disabled";
prog_char string_10 [] PROGMEM = "Camera";
prog_char string_11 [] PROGMEM = "Motor";
prog_char string_12 [] PROGMEM = "Program";
prog_char string_13 [] PROGMEM = "General";
prog_char string_14 [] PROGMEM = "Settings";
prog_char string_15 [] PROGMEM = "Version info";
prog_char string_16 [] PROGMEM = "Cycle length";
prog_char string_17 [] PROGMEM = "Focus time";
prog_char string_18 [] PROGMEM = "Exp. time";
prog_char string_19 [] PROGMEM = "Focus behav.";
prog_char string_20 [] PROGMEM = "Max. shots";
prog_char string_21 [] PROGMEM = "Post delay";
prog_char string_22 [] PROGMEM = "Test shot";
prog_char string_23 [] PROGMEM = "Motor steps ";
prog_char string_24 [] PROGMEM = "Direction";
prog_char string_25 [] PROGMEM = "Motor home";
prog_char string_26 [] PROGMEM = "Motor sleep";
prog_char string_27 [] PROGMEM = "Max steps";
prog_char string_28 [] PROGMEM = "Ramp";
prog_char string_29 [] PROGMEM = "Operat. mode";
prog_char string_30 [] PROGMEM = "B-Light time";
prog_char string_31 [] PROGMEM = "B-Light powr";
prog_char string_32 [] PROGMEM = "System time ";
prog_char string_33 [] PROGMEM = "Save settgs.";
prog_char string_34 [] PROGMEM = "Autosave";
prog_char string_35 [] PROGMEM = "Reset";
prog_char string_36 [] PROGMEM = "Developers";
prog_char string_37 [] PROGMEM = "(alphabt. o.):";
prog_char string_38 [] PROGMEM = "Airic Lenz,";
prog_char string_39 [] PROGMEM = "Alvarocalvo,";
prog_char string_40 [] PROGMEM = "C.A. Church,";
prog_char string_41 [] PROGMEM = "Marc Lane";
prog_char string_42 [] PROGMEM = "For questions";
prog_char string_43 [] PROGMEM = "have a look at";
prog_char string_44 [] PROGMEM = "openmoco.org ";
prog_char string_45 [] PROGMEM = ""; // reserve
prog_char string_46 [] PROGMEM = "Press SELECT to";
prog_char string_47 [] PROGMEM = "";
prog_char string_48 [] PROGMEM = "";
prog_char string_49 [] PROGMEM = "";
prog_char string_50 [] PROGMEM = "";
prog_char string_51 [] PROGMEM = "";
prog_char string_52 [] PROGMEM = "";
prog_char string_53 [] PROGMEM = "do a test shot.";
prog_char string_54 [] PROGMEM = "";
prog_char string_55 [] PROGMEM = "";
prog_char string_56 [] PROGMEM = "";
prog_char string_57 [] PROGMEM = "";
prog_char string_58 [] PROGMEM = "";
prog_char string_59 [] PROGMEM = "Set home";
prog_char string_60 [] PROGMEM = "";
prog_char string_61 [] PROGMEM = "Add program ";
prog_char string_62 [] PROGMEM = "add a program.";
prog_char string_63 [] PROGMEM = "Start time";
prog_char string_64 [] PROGMEM = "Weekdays";
prog_char string_65 [] PROGMEM = "Duration";
prog_char string_66 [] PROGMEM = "Move home";
prog_char string_67 [] PROGMEM = "Status";
prog_char string_68 [] PROGMEM = "Delete";
prog_char string_69 [] PROGMEM = "";
prog_char string_70 [] PROGMEM = "";
prog_char string_71 [] PROGMEM = "";
prog_char string_72 [] PROGMEM = "save settings.";
prog_char string_73 [] PROGMEM = "Autosave settgs:";
prog_char string_74 [] PROGMEM = "reset settings.";
prog_char string_75 [] PROGMEM = "Restoring CFG..";
prog_char string_76 [] PROGMEM = "Restarting..";
prog_char string_77 [] PROGMEM = "set motor home.";
prog_char string_78 [] PROGMEM = "Move to home";
prog_char string_79 [] PROGMEM = "Moving motor to";
prog_char string_80 [] PROGMEM = "home. Stand by.";
prog_char string_81 [] PROGMEM = "Program start:";
prog_char string_82 [] PROGMEM = "M T W T F S S";
prog_char string_83 [] PROGMEM = "Duration:";
prog_char string_84 [] PROGMEM = "Move home @ end:";
prog_char string_85 [] PROGMEM = "Program status:";
prog_char string_86 [] PROGMEM = "delete program.";
prog_char string_87 [] PROGMEM = "high w. shutter";
prog_char string_88 [] PROGMEM = "low w. shutter";
prog_char string_89 [] PROGMEM = "continuous";
prog_char string_90 [] PROGMEM = "shoot-move-shoot";
prog_char string_91 [] PROGMEM = "anti-clockwise";
prog_char string_92 [] PROGMEM = "clockwise";
prog_char string_93 [] PROGMEM = "A limit switch";
prog_char string_94 [] PROGMEM = "was triggered!";
prog_char string_95 [] PROGMEM = "Max motor step";
prog_char string_96 [] PROGMEM = "limit reached!";
prog_char string_97 [] PROGMEM = "Max camera shot";
prog_char string_98 [] PROGMEM = "";
prog_char string_99 [] PROGMEM = "Post delay ";
prog_char string_100[] PROGMEM = "Motor post delay:";
prog_char string_101[] PROGMEM = "Max speed";
prog_char string_102[] PROGMEM = "Max speed delay:";
prog_char string_103[] PROGMEM = "Min speed";
prog_char string_104[] PROGMEM = "Min speed delay:";
prog_char string_105[] PROGMEM = "Lmt-Switches";
prog_char string_106[] PROGMEM = "";
prog_char string_107[] PROGMEM = "Jog";
prog_char string_108[] PROGMEM = "Motor jog:";
prog_char string_109[] PROGMEM = "Up=CW Down=CCW";
// Now set up a table to refer to the strings (a simple list
// of all the strings we defined)
PROGMEM prog_char *string_table[] = {
string_0, string_1, string_2, string_3, string_4,
string_5, string_6, string_7, string_8, string_9,
string_10, string_11, string_12, string_13, string_14,
string_15, string_16, string_17, string_18, string_19,
string_20, string_21, string_22, string_23, string_24,
string_25, string_26, string_27, string_28, string_29,
string_30, string_31, string_32, string_33, string_34,
string_35, string_36, string_37, string_38, string_39,
string_40, string_41, string_42, string_43, string_44,
string_45, string_46, string_47, string_48, string_49,
string_50, string_51, string_52, string_53, string_54,
string_55, string_56, string_57, string_58, string_59,
string_60, string_61, string_62, string_63, string_64,
string_65, string_66, string_67, string_68, string_69,
string_70, string_71, string_72, string_73, string_74,
string_75, string_76, string_77, string_78, string_79,
string_80, string_81, string_82, string_83, string_84,
string_85, string_86, string_87, string_88, string_89,
string_90, string_91, string_92, string_93, string_94,
string_95, string_96, string_97, string_98, string_99,
string_100, string_101, string_102, string_103, string_104,
string_105, string_106 // , string_107, string_108, string_109
// UI status flags
// B0 = backlight on / off
// B1 = ui repaint flag
// B2 = settings autosave flag
// B3 = settings were changed flag
// B4 = 24h / 12h time (24 = LOW, 12 = HIGH) not used yet
// B5 = long key press
// B6 = message on screen
// B7 =
byte ui_status = B11100000;
// wait time until backlight turns off in milliseconds
unsigned int backlight_wait = 10;
// backlight level in percent
byte backlight_level=100;
// a variable to remeber when a message started
unsigned long message_start_time;
byte message_duration;
// our Real time clock object
RTC_DS1307 RTC;
// and the current time of the system
DateTime time;
// Arduino Setup Procedure
//Serial.begin(9600);
pinMode(MOTOR_DIR_PIN, OUTPUT);
pinMode(MOTOR_STEP_PIN, OUTPUT);
pinMode(MOTOR_SLEEP_PIN, OUTPUT);
pinMode(CAMERA_PIN, OUTPUT);
pinMode(FOCUS_PIN, OUTPUT);
pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
// set motor to sleep
digitalWrite(MOTOR_SLEEP_PIN, LOW);
// init the LCD display
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear();
// did we previously save settings to eeprom?
// is config saved and has the config has the correct version?
if ((is_eeprom_saved()) &&
(is_OK_eeprom_version())) {
load_config();
write_config();
write_eeprom_version();
// enable backlight
setBacklightLevel();
byte scroll_up[8] = {
B00100,
B01110,
B11111,
B00100,
B00100,
B00000,
B00000,
B00000
byte scroll_down[8] = {
B00000,
B00000,
B00000,
B00100,
B00100,
B11111,
B01110,
B00100
// create the special chars we need for the UI
lcd.createChar(0, scroll_up);
lcd.createChar(1, scroll_down);
Serial.print(freeMemory());
Serial.println(" byte free.");
// welcome screen
lcd.setCursor(3, 0);
lcd.print("miniEngine");
lcd.setCursor(6, 1);
lcd.print("v");
lcd.print(VERSION);
lcd.print(".");
lcd.print(SUBVERSION);
delay(1500);
// RTC Stuff
Wire.begin();
RTC.begin();
// Arduinos eternal loop procedure
// do the screen stuff
do_screen();
// programm is running
if (action_status & B00001000) {
// C O N T I N U O U S m o d e
if (action_status & B10000000) {
// do some continuous steps
doMotorContinuous();
// if it is time or the "start a new cycle immediately" flag is set
if ((action_status & B00100000) ||
((program_start_time + ((unsigned long) cycle_length * 500UL * (unsigned long) camera_shoot_count)) <= millis())) {
// if not exposing right now and not in camera post delay (makes this sense in continuous??)
if (!(action_status & B01000000) &&
!(action_status & B00010000) &&
!(action_status & B00000100)) {
// should we do focussing?
if (camera_focus_time > 0) {
camera_focus();
// shoot camera
camera_shoot();
// delete the start immediately flag if set
if (action_status & B00100000) {
bitClear(action_status, 5); // B11011111
// is camera focussing right now?
if (action_status & B01000000) {
// did we focus the time we wanted to focus?
if((action_start_time + (unsigned long) camera_focus_time) <= millis()) {
// stop focussing (this function automatically starts the exposure)
camera_stop_focus();
// is camera exposing right now?
if (action_status & B00010000) {
// did we exposed the time we wanted to expose?
if((action_start_time + (unsigned long)camera_exp_time) <= millis()) {
// stop shooting
camera_stop_shoot();
// now check the limit switches if we need to stop the program
// this function is called as late as possible after the key reading because
// analogRead needs some pre delay time to deliver accurate measurements...
check_limit_switches();
// S H O O T - M O V E - S H O O T m o d e
else {
// if not focussing or exposing right now and not in camera or motor post delay
!(action_status & B00000100) &&
!(action_status & B00000001) ) {
camera_focus();
// shoot camera
camera_shoot();
// toggle the start immediately flag to off
if((action_start_time + camera_exp_time) <= millis()) {
// stop shooting
// post exposure delay
if (action_status & B00000100) {
if((action_start_time + (unsigned long) camera_exp_time + (unsigned long) camera_exp_post) <= millis()) {
camera_stop_post();
// time for the engines
if (action_status & B00000010) {
// do the blocking motor phase with error check
doMotorPhase(true);
motor_stop();
// this function is called after the blocking motor phase because
// measurements...
// motor post delay
if (action_status & B00000001) {
// did we waited the time we wanted to wait?
if((action_start_time + (unsigned long) motor_post) <= millis()) {
// clear the waintg flag...
bitClear(action_status, 0); // B11111110
} // operation mode
// if the programm is running and we are in contiuous mode
continuous_check();
} // program is running
// read the time from the RTC (valid for the next loop)
time = RTC.now();
continuous_check();
// the function that checks if we need to start or stop a program
check_programs();
continuous_check();
// check if there are programs that will be triggered in the future
// this is done for being able to display this information ("smart P")
check_programFuture();
Thank you
