Perhaps the following code may be of help:
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <driver/adc.h>
#include "esp32-hal-ledc.h"
#include <HardwareSerial.h>
#include <SimpleKalmanFilter.h>
#include "MHZ19.h"
MHZ19 myMHZ19;
Adafruit_BME680 bme( GPIO_NUM_5 ); // use hardware SPI, set GPIO pin to use
//Adafruit_ST7789 tft = Adafruit_ST7789( TFT_CS , TFT_DC , TFT_MOSI , TFT_SCLK , TFT_RST );
Adafruit_ST7789 tft = Adafruit_ST7789( GPIO_NUM_15, GPIO_NUM_0, GPIO_NUM_13, GPIO_NUM_14, GPIO_NUM_22 );
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
#define evtDoParticleRead ( 1 << 0 ) // declare an event
#define evtWaitForBME ( 1 << 1 )
#define evtParseMQTT ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
QueueHandle_t xQ_WindChillDewPoint;
QueueHandle_t xQ_eData; // environmental data to be displayed on the screen
struct stu_eData
float Temperature = 0.0f;
float Pressure = 0.0f;
float Humidity = 0.0f;
float IAQ = 0.0f; // Index Air Quality
float RM0 = 0.0f; // Remaining Moisture from sensor 0
float PM2 = 0.0f; // particles in air
float WS = 0.0f; // wind speed
String WD = ""; // wind direction
float RF = 0.0f; // rainfall
float WSV = 0.0f; // weather station volts
float WSC = 0.0f; // weather station current
float WSP = 0.0f; // weather station power
float WindChill = 0.0f; //windchill
float DewPoint = 0.0f; //dew point or dew index
} x_eData; // environmental data
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
char payload [payloadSize] = {'\0'};
String topic ;
} x_message;
const float oGasResistanceBaseLine = 149598.0f;
int mqttOK = 0;
int CO2 = 0;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_PublishPM;
SemaphoreHandle_t sema_mqttOK;
//serial(2) = pin25 RX, pin26 TX
HardwareSerial co2Serial ( 2 );
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
log_i("Connected to WiFi access point");
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR oneshot_timer_callback( void* arg )
BaseType_t xHigherPriorityTaskWoken;
xEventGroupSetBitsFromISR( eg, evtDoParticleRead, &xHigherPriorityTaskWoken );
} //void IRAM_ATTR oneshot_timer_callback( void* arg )
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
x_message.topic = ""; //clear topic string buffer
x_message.topic = topic; //store new topic
int i = 0; // extract payload
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
x_eData.WD.reserve(50);
x_message.topic.reserve( payloadSize );
xQ_WindChillDewPoint = xQueueCreate( 1, sizeof(stu_eData) );
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
xQ_eData = xQueueCreate( 1, sizeof(stu_eData) ); // sends a queue copy of the structure
sema_PublishPM = xSemaphoreCreateBinary();
xSemaphoreGive( sema_PublishPM );
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
ledcSetup( 4, 12000, 8 ); // ledc: 4 => Group: 0, Channel: 2, Timer: 1, led frequency, resolution bits
ledcAttachPin( GPIO_NUM_12, 4 ); // gpio number and channel
ledcWrite( 4, 0 ); // write to channel number 4
eg = xEventGroupCreate(); // get an event group handle
// output mode
gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
io_cfg.mode = GPIO_MODE_OUTPUT; // set gpio mode
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) ); //bit mask of the pins to set
gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
gpio_set_level( GPIO_NUM_4, LOW); // set air particle sensor trigger pin to LOW
// input mode
io_cfg = {}; // reinitialize the gpio configuration structure
io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_27) ); //bit mask of the pins to set, assign gpio number to be configured
// set up A:D channels, refer: https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36
// https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000, NULL, 5, NULL, 1 );
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 15000, NULL, 6, NULL, 1 );
xTaskCreatePinnedToCore( DoTheBME680Thing, "DoTheBME280Thing", 20000, NULL, 5, NULL, 1);
xTaskCreatePinnedToCore( fDoParticleDetector, "fDoParticleDetector", 6000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fDoTheDisplayThing, "fDoTheDisplayThing", 23000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fScreenBlanking, "fScreenBlanking", 2000, NULL, 2, NULL, 1 );
xTaskCreatePinnedToCore( fGetCO2, "fGetCO2", 4500, NULL, 2, NULL, 1 );
xTaskCreatePinnedToCore( fParseDewPointWindChill, "fParseDewPointWindChill", 4500, NULL, 2, NULL, 1 );
} //void setup()
250-400ppm Normal background concentration in outdoor ambient air
400-1,000ppm Concentrations typical of occupied indoor spaces with good air exchange
1,000-2,000ppm Complaints of drowsiness and poor air.
2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
>40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
void fParseDewPointWindChill( void *pvParameters )
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
struct stu_message px_message;
String sDewPoint = "";
String sWindChill = "";
sDewPoint.reserve( payloadSize );
sWindChill.reserve( payloadSize );
for (;;)
if ( xQueueReceive(xQ_WindChillDewPoint, &px_message, portMAX_DELAY) == pdTRUE )
sDewPoint = px_message.payload;
int commaIndex = sDewPoint.indexOf(',');
sWindChill.concat ( sDewPoint.substring(0, commaIndex) );
sDewPoint.remove( 0, (commaIndex + 1) );
x_eData.WindChill = sWindChill.toFloat();
x_eData.DewPoint = sDewPoint.toFloat();
sDewPoint = "";
sWindChill = "";
//log_i( " high watermark % d", uxTaskGetStackHighWaterMark( NULL ) );
vTaskDelete( NULL );
void fGetCO2 ( void *pvParameters )
uint64_t TimePastKalman = esp_timer_get_time();
myMHZ19.begin( co2Serial );
myMHZ19.autoCalibration();
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 1000; //delay for mS
SimpleKalmanFilter KF_CO2( 1.0f, 1.0f, .01f );
for ( ;; )
KF_CO2.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f );
CO2 = KF_CO2.updateEstimate( myMHZ19.getCO2() ); // apply simple Kalman filter
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
MQTTclient.publish( topicCO2, String(CO2).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
// process wind chill and dew point
vTaskDelayUntil( &xLastWakeTime, xFrequency );
} //void fMHZ19B ( void *pvParameters )
void fScreenBlanking( void *pvParameters )
int TimeOfPause = 10000 * 1000;
uint64_t PauseStartTime = esp_timer_get_time();
bool Pause = false;
const int brightness = 250;
int countUpDown = brightness;
for ( ;; )
if (!Pause )
//if motion detect then show display otherwise blank display
if ( !(gpio_get_level( GPIO_NUM_27)) )
for ( countUpDown; countUpDown-- > 0; )
ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
vTaskDelay( 7 );
Pause = true;
ledcWrite( 4, brightness );
// still detecting movement reset blanking pause time
if ( gpio_get_level( GPIO_NUM_27) )
PauseStartTime = esp_timer_get_time(); // extend pause blanking time
if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
Pause = false;
vTaskDelay( 250 );
} //void fScreenBlanking( void *pvParameters )
void fparseMQTT( void *pvParameters )
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
mqttOK = 0;
if ( px_message.topic == topicRemainingMoisture_0 )
x_eData.RM0 = String(px_message.payload).toFloat();
if ( px_message.topic == topicWindSpeed )
x_eData.WS = String(px_message.payload).toFloat();
if ( px_message.topic == topicWindDirection )
x_eData.WD = "";
x_eData.WD = String(px_message.payload);
if ( px_message.topic == topicRainfall )
x_eData.RF = String(px_message.payload).toFloat();
if ( px_message.topic == topicWSVolts )
x_eData.WSV = String(px_message.payload).toFloat();
if ( px_message.topic == topicWSCurrent )
x_eData.WSC = String(px_message.payload).toFloat();
if ( px_message.topic == topicWSPower )
x_eData.WSP = String(px_message.payload).toFloat();
if ( px_message.topic == topicDPnWI )
xQueueSend( xQ_WindChillDewPoint, (void *) &px_message, 1 );
} //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
} //for(;;)
} // void fparseMQTT( void *pvParameters )
void fDoTheDisplayThing( void * parameter )
tft.init( 240, 320 ); // Init ST7789 320x240
tft.setRotation( 3 );
tft.setTextSize( 3 );
tft.fillScreen( ST77XX_BLACK );
tft.setTextWrap( false );
struct stu_eData px_eData;
ledcWrite( 4, brightness ); //backlight set
const int MaxString = 20;
String oldTempString = "";
String oldHumidityString = "";
String oldAQIString = "";
String oldRainfall = "";
String oldWindDirection = "";
String oldAirPressure = "";
String oldRMO = "";
String oldPM2 = "";
String oldPower = "";
oldHumidityString.reserve( MaxString );
oldWindDirection.reserve( MaxString );
oldAirPressure.reserve( MaxString );
oldTempString.reserve( MaxString );
oldAQIString.reserve( MaxString );
oldRainfall.reserve( MaxString );
oldPower.reserve( MaxString );
oldRMO.reserve( MaxString );
oldPM2.reserve( MaxString );
bool Tick = true;
const int numOfColors = 40;
/* https://chrishewett.com/blog/true-rgb565-colour-picker/#:~:text=A%20true%20RGB565%20colour%20picker%2021st%20Oct%202017,in%205%20bits%20and%20green%20in%206%20bits. */
int colors[numOfColors] = { ST77XX_BLACK, ST77XX_RED, ST77XX_WHITE, ST77XX_BLUE, ST77XX_GREEN, ST77XX_CYAN, ST77XX_MAGENTA, ST77XX_YELLOW, 0xd55b, 0xee09,
0x2e15, 0xcb43, 0x6bad, 0x126f, 0x1264, 0xe264, 0xe7e4, 0x87e4, 0x87fe, 0x876a,
0xe304, 0x1cc4, 0xf4c4, 0xf4da, 0xcf66, 0xa879, 0x7f28, 0x4f37, 0xfa97, 0x6195,
0X8162, 0xc962, 0x517b, 0x325b, 0xea5b, 0x179b, 0xff80, 0xf960, 0x416d, 0x7bd1
int colorCounter = 1;
for (;;)
if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
tft.setCursor( 0, 0 );
tft.setTextColor( colors[0] );
tft.print( oldTempString );
tft.setTextColor( colors[colorCounter] );
oldTempString = "";
if ( Tick )
oldTempString.concat( "iTemp " + String(px_eData.Temperature) + "F" );
oldTempString.concat( "Wind Chill " + String(px_eData.WindChill) + "F" );
tft.println( oldTempString );
tft.setCursor( 0, 30 );
tft.print( oldHumidityString );
oldHumidityString.concat( "iHum " + String(px_eData.Humidity) + "%" );
tft.println( oldHumidityString );
tft.setCursor( 0, 60 );
tft.print( oldAirPressure );
//oldAirPressure.concat( "Pres " + String(px_eData.Pressure) + "mmHg" );
oldAirPressure.concat( "Dew Pt. " + String(px_eData.DewPoint) + "F" );
tft.println( oldAirPressure );
tft.setCursor( 0, 90 );
tft.print( oldAQIString );
oldAQIString = "";
oldAQIString.concat( "iAQI " + String(px_eData.IAQ) + "%" );
tft.println( oldAQIString );
tft.setCursor( 0, 120 );
tft.print( oldRMO );
oldRMO = "";
if ( Tick )
oldRMO.concat( "iRM0 " + String(px_eData.RM0) + "%" );
oldRMO.concat( "iCO2 " + String(CO2) + "ppm" );
tft.println( oldRMO );
tft.setCursor( 0, 150 );
tft.print( oldPM2 );
oldPM2 = "";
oldPM2.concat( "PM2 " + String(px_eData.PM2) + "ug/m3" );
tft.println( oldPM2 );
tft.setCursor( 0, 180 );
tft.print( oldPower );
oldPower = "";
oldPower.concat( String(px_eData.WSV) + " Volts" );
//oldPower.concat( String(px_eData.WSV) + "V " + String(int(px_eData.WSC * 1000.0f)) + "mA " + String((int(px_eData.WSP * 1000.0f))) + "mW" );
tft.println( oldPower );
colorCounter++;
if ( colorCounter > (numOfColors - 1) )
colorCounter = 1;
Tick = !Tick;
} //if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
} //for (;;)
} //void fDoTheDisplayTHing( void * parameter )
void fmqttWatchDog( void * paramater )
int maxNonMQTTresponse = 5;
for (;;)
vTaskDelay( 1000 );
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
float fCalulate_IAQ_Index( int gasResistance, float Humidity)
float hum_baseline = 40.0f;
float hum_weighting = 0.25f;
float gas_offset = 0.0f;
float hum_offset = 0.0f;
float hum_score = 0.0f;
float gas_score = 0.0f;
gas_offset = oGasResistanceBaseLine - float( gasResistance );
hum_offset = float( Humidity ) - hum_baseline;
// calculate hum_score as distance from hum_baseline
if ( hum_offset > 0.0f )
hum_score = 100.0f - hum_baseline - hum_offset;
hum_score /= ( 100.0f - hum_baseline );
hum_score *= ( hum_weighting * 100.0f );
hum_score = hum_baseline + hum_offset;
hum_score /= hum_baseline;
hum_score *= ( 100.0f - (hum_weighting * 100.0f) );
//calculate gas score as distance from baseline
if ( gas_offset > 0.0f )
gas_score = float( gasResistance ) / oGasResistanceBaseLine;
gas_score *= ( 100.0f - (hum_weighting * 100.0f ) );
gas_score = 100.0f - ( hum_weighting * 100.0f );
return ( hum_score + gas_score );
} //void fCalulate_IAQ_Index( int gasResistance, float Humidity):
void fDoParticleDetector( void * parameter )
ug/m3 AQI Lvl AQ (Air Quality)
(air Quality Index)
0-35 0-50 1 Excellent
35-75 51-100 2 Average
75-115 101-150 3 Light pollution
115-150 151-200 4 moderate
150-250 201-300 5 heavy
250-500 >=300 6 serious
float ADbits = 4095.0f;
float uPvolts = 3.3f;
float adcValue = 0.0f;
float dustDensity = 0.0f;
float Voc = 0.6f; // Set the typical output voltage, when there is zero dust.
const float K = 0.5f; // Use the typical sensitivity in units of V per 100ug/m3.
xEventGroupWaitBits (eg, evtWaitForBME, pdTRUE, pdTRUE, portMAX_DELAY );
const TickType_t xFrequency = 100; //delay for mS
for (;;)
//enable sensor led
gpio_set_level( GPIO_NUM_4, HIGH ); // set gpio 4 to high to turn on sensor internal led for measurement
esp_timer_start_once( oneshot_timer, 280 ); // trigger one shot timer for a 280uS timeout, warm up time.
xEventGroupWaitBits (eg, evtDoParticleRead, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading from the dust sensor
gpio_set_level( GPIO_NUM_4, LOW );//Shut off the sensor LED
adcValue = ( adcValue * uPvolts ) / ADbits; //calculate voltage
dustDensity = (adcValue / K) * 100.0; //convert volts to dust density
if ( dustDensity < 0.0f )
dustDensity = 0.00f; // make negative values a 0
if ( xSemaphoreTake( sema_PublishPM, 0 ) == pdTRUE ) // don't wait for semaphore to be available
//log_i( "ADC volts %f Dust Density = %ug / m3 ", adcValue, dustDensity ); // print the calculated voltage and dustdensity
MQTTclient.publish( topicInsidePM, String(dustDensity).c_str() );
x_eData.PM2 = dustDensity;
}// end fDoParticleDetector()
void DoTheBME680Thing( void *pvParameters )
SPI.begin(); // initialize the SPI library
vTaskDelay( 10 );
if (!bme.begin()) {
log_i("Could not find a valid BME680 sensor, check wiring!");
while (1);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
//wait for a mqtt connection
vTaskDelay( 250 );
xEventGroupSetBits( eg, evtWaitForBME );
const TickType_t xFrequency = 1000 * 15; //delay for mS
String bmeInfo = "";
bmeInfo.reserve( 100 );
for (;;)
x_eData.Temperature = bme.readTemperature();
x_eData.Temperature = ( x_eData.Temperature * 1.8f ) + 32.0f; // (Celsius x 1.8) + 32
x_eData.Pressure = bme.readPressure();
x_eData.Pressure = x_eData.Pressure / 133.3223684f; //converts to mmHg
x_eData.Humidity = bme.readHumidity();
x_eData.IAQ = fCalulate_IAQ_Index( bme.readGas(), x_eData.Humidity );
//log_i( " temperature % f, Pressure % f, Humidity % f IAQ % f", x_eData.Temperature, x_eData.Pressure, x_eData.Humidity, x_eData.IAQ);
bmeInfo.concat( String(x_eData.Temperature, 2) );
bmeInfo.concat( "," );
bmeInfo.concat( String(x_eData.Pressure, 2) );
bmeInfo.concat( String(x_eData.Humidity, 2) );
bmeInfo.concat( String(x_eData.IAQ, 2) );
if ( MQTTclient.connected() )
MQTTclient.publish( topicInsideInfo, bmeInfo.c_str() );
xSemaphoreGive( sema_PublishPM ); // release publish of dust density
mqttOK ++;
xQueueOverwrite( xQ_eData, (void *) &x_eData );// send data to display
bmeInfo = ""; // empty the string buffer
findDewPointWithHumidity( x_eData.Humidity, x_eData.Temperature );
// log_i( "DoTheBME280Thing high watermark % d", uxTaskGetStackHighWaterMark( NULL ) );
vTaskDelete ( NULL );
Important to not set vTaskDelay/vTaskDelayUntil to less then 10. Errors begin to develop with the MQTT and network connection.
makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; //delay for ms
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status % s WiFi status % s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
void connectToMQTT()
byte mac[5]; // create client ID from mac address
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe ( topicOK );
MQTTclient.subscribe ( topicRemainingMoisture_0 );
MQTTclient.subscribe ( topicWindSpeed );
MQTTclient.subscribe ( topicWindDirection );
MQTTclient.subscribe ( topicRainfall );
MQTTclient.subscribe ( topicWSVolts );
MQTTclient.subscribe ( topicWSCurrent );
MQTTclient.subscribe ( topicWSPower );
MQTTclient.subscribe ( topicDPnWI );
} //void connectToMQTT()
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
float findDewPointWithHumidity( float humi, float temperature )
//Celcius
float ans = (temperature - (14.55 + 0.114 * temperature) * (1 - (0.01 * humi)) - pow(((2.5 + 0.007 * temperature) * (1 - (0.01 * humi))), 3) - (15.9 + 0.117 * temperature) * pow((1 - (0.01 * humi)), 14));
//log_i( "%f", ans );
return ans;
void loop() { }
See void fparseMQTT( void *pvParameters ) how the payload is broken out and applied to variables that are used elsewhere.
