[SOLVED] I2C Coms multiple values
Hi I am trying to send multiple things over I2C (only x and Trims at the moment) when input 3 on the master is high
x will end up being a value between 1 and 101, however just for testing it will be 0, 3, 4 over I2C and then can be set to 10 with the master.
Trims will be a value between 0 and 255 from an analog input 0 on the slave
I can get both of them working by them selves however when I try to do both at once only one will come through.
I have the following code
Master
// Master
#include <Wire.h>
int x=0;
int Trims=0;
  Wire.begin();  // Start I2C as Master
  if(digitalRead(3)==HIGH){
    Wire.requestFrom(5,4);  //Also not sure how many bits I should be requesting
    x = Wire.read();
    //Trims = Wire.read();
  Serial.print("x = ");
  Serial.println(x);
  //Serial.print("Trims = ");
  //Serial.println(Trims);
  if(digitalRead(3)==LOW) x=10;
Slave
// Slave
#include <Wire.h>
int x=0;
int Trims=0;
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  Wire.begin(5);  // Start I2C as slave with address 5
  Wire.onRequest(RequestData);
  Trims = analogRead(0);
  map(Trims, 0, 1024, 0, 255);
  constrain(Trims, 0, 255);
  if(digitalRead(3)==HIGH) x=3;
  else if(digitalRead(4)==HIGH) x=4;
  else x=0;
  delay(100);
void RequestData()
 Wire.write(x);
 //Wire.write(Trims);
All I have been doing to include or remove x or Trims is add or remove // where needed.
Not sure if I am going about this the right way or not.
Any help with this would be appreciated.
a typical int is 2 bytes
So if I am requesting 2 ints it should be 4 bytes?
anyone know how to send to ints at the same time, or one straight after the other?
Could I do this by sending an array of data? Something like
int I2Cdata[]={x, Trims}; then
Wire.write(I2Cdata[]);  // in void RequestData ()
Never mind everyone.
I have managed to figure this out myself.
I used an array to send the data.
Bellow is the code for anyone else wanting to know how to accomplish this.
Master
// Master
#include <Wire.h>
int x=0;
int Trims=0;
int I2Cdata[2];
    I2Cdata[0]=Wire.read();
    I2Cdata[1]=Wire.read();
      x = I2Cdata[0];
      Trims = (I2Cdata[1]);
  Serial.println(x);
Slave
// Slave
#include <Wire.h>
int x=0;
int Trims=0;
unsigned char I2Cdata[2];
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  else x=6;
  I2Cdata[0] = x;
  I2Cdata[1] = Trims;
  delay(100);
void RequestData()
 Wire.write(I2Cdata,2);
Cheers
Grant…
Well done,
now you figured out yourself you will never forget :wink:
