I am trying to add an I2C LCD display to my project.
I have got the LCD working using LiquidCrystal_I2C but that library uses the standard Wire library, and my project cannot use 'Wire' as I require a 'Repeat Start command.
The project is working using the I2C_Master library and using a parallel LCD, so to add the I2C LCD as another device on the bus, it seems like I will need an LCD sketch or library the will run with I2C_Master.
(I have tried it with both but although it compiles OK they seem to conflict as the bus stops running.
Does anyone know of a suitable library, or can anyone advise on adapting or writing something
Thanks
