SOLVED I2C only works without wire.begin?
So this one is new (to me):
I have a PCA9555DB port extender, and it works just like I want it, but only if I add the Wire.begin() in my setup (logical).
I have a PCF85134HL LCD display controller, and it DOES work but only if I remove the Wire.begin() from my code! It runs normally with all the wire functions (Weird stuff!).
Unfortunately, I have both in my project so I need to fix this somehow, but it's above my skills ATM. I could post my code, but not sure if the fault is in there, both IC's work, just not together.
I tried disabling the internal pull-ups, didn't work. Anyone have an idea where to look?
External libraries?
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <EEPROM.h>
#include <Wire.h>
#include <TimerOne.h>
#include <avr/interrupt.h>
Did removed TimerOne to see if that’s the problem, had the same problems.
Are there libraries for controlling the PCA9555DB & PCF85134HL? I would guess a library has already done a wire.begin() as it's initialized and that's why one device works without it in your main code but the other device should still work without another wire.begin() if it's initialized/called after the first one. Time to post your code (using code tags or attach to your post)
Tried the TWIinit() as a test, no luck there. I'm communicating with both IC's directly, without the use of a external library.
Code is messy now, i'm debugging the life out of it! The loop contents I removed, it's really an initialization thing...
#include <Wire.h>
int Var1;
    Serial.begin(19200);
  //Wire.begin();
  Wire.beginTransmission(0x70);
  Wire.write(0x80);
  Wire.write(0xC8);
  Wire.write(0x00);
  Wire.write(0xF0);
  Var1 = Wire.endTransmission();
  Serial.write(Var1);
  Wire.beginTransmission(0x20);
  Wire.write(6);
  Wire.write(0xFF);  // low byte
  Wire.write(0xFF);    // high byte
  Serial.write(Var1);
Even doing just this, the problem occurs…
Can’t make it any better…
When I include the Wire.begin, the port expander returns a “0” (All OK) and the LCD controller a “2” (wrong address).
When I remove it, it’s the other way around…
Which Arduino board, or Arduino compatible microcontroller are you using ? Do you use the newest Arduino IDE 1.0.6 or 1.5.8 BETA ?
You must use Wire.begin() of course, it means the LCD controller is not at 0x20.
Run the sketch of the i2c_scanner : http://playground.arduino.cc/Main/I2cScanner It will find the addresses of both chips. The address of the expander can be 0x20 to 0x27, the LCD controller can be at 0x38 or 0x39.
Peter_n: Which Arduino board, or Arduino compatible microcontroller are you using ? Do you use the newest Arduino IDE 1.0.6 or 1.5.8 BETA ?
Arduino Ethernet based board, And the arduino IDE 1.0.5-r2. The I2C scanner got me more addresses than I2C devices in the circuit, but one of them was 0x38. When i tried it, IT WORKED! awesomecakes! +1 But now i'm wondering, how did you know? And why does the documentation of the LCD device say "listens to the address 0x70 or 0x71"? :S
I opened both datasheet, scrolled down for a picture of the slave address.
The Arduino Wire library uses 0 to 127. That is bit 7 to bit 1 and shifted to the right (bit 0 is the read/write bit). Some manufacturers use the bits of the address without the shifting.
Where did you find that about 0x70 and 0x71, I can not even find the word "listen" in the datasheet : http://www.nxp.com/products/interface_and_connectivity/lcd_drivers/lcd_segment_drivers/PCF85134HL.html
Page 27, chapter 8.6 I2C-bus protocol
And your 100% right, I used the flat out address and didn’t take the bit shift into account from the wire library.
Blink a few times with your eyes and look at it again: "Two I2C-bus slave addresses (0111 000 and 0111 001) are used..."
That are 7 bits, with a space in the fysical location of the bits over the I2C bus, but bit 0 is omitted.
0111 000 = 011 - 1 000 = 0x38
