[Solved!] I2C to transfer data between two Arduinos Unos
EDIT: solve! I had pin 4 and pin 5 of the digital I/O instead of the analog I/O. Stupid!!!
Hello,
I’m trying to follow the I2C example from this forum and from a couple of other places. A “writer” arduino sends a struct with two integers. A “reader” Arduino prints out the two ints it reads. Hardware wise, I have pin4, pin5, and ground connected between the two Arduinos. Pin4 to Pin 4 and Pin5 to Pin5, which are suppose to be the analog pins doing the I2C. I can verify that the “Writer” Arduino is sending values X: 1, 2, 3, 4…etc. But the Reader Arduino isn’t seeing the data, and is not executing receiveEvent().
I’d appreciate any input on why this might not be working.
“Writer” Arduino, sending the values
// I2C communication between 2 Arduinos
// Analog joystick connected to analog pins A0 and A1
// Values from joystick are sent to the slave
#include <Wire.h>
const byte SLAVE_ADDRESS = 42;
int startx = 0;
int starty = 10;
  Serial.begin (9600);
  Wire.begin ();
}  // end of setup
  struct
    int X;
    int Y;
    } XY;
  startx = startx + 1;
  starty = starty + 1;
  XY.X = startx;
  XY.Y = starty;
  if (startx > 100)
    startx = 0;
  if (starty > 100)
    starty = 0;
  Wire.beginTransmission (SLAVE_ADDRESS);
  Wire.write ((byte *) &XY, sizeof XY);
  Wire.endTransmission ();
  Serial.println (XY.X);
  delay(4000);
“Reader” Arduino, reading the values from I2C
// Slave receives the integers X and Y from the master
// Values X and Y are printed to the serial monitor
#include <Wire.h>
const byte MY_ADDRESS = 42;
  Wire.begin (MY_ADDRESS);
  Wire.onReceive (receiveEvent);
  Serial.println ("hi hi");
}  // end of setup
volatile struct
   int X;
   int Y;
   } XY;
volatile boolean haveData = false;
  if (haveData)
    Serial.print ("Received X = ");
    Serial.print ("Received Y = ");
    Serial.println (XY.Y);
    haveData = false;
  }  // end if haveData
}  // end of loop
// called by interrupt service routine when incoming data arrives
void receiveEvent (int howMany)
  if (howMany < sizeof XY)
    return;
  // read into structure
  byte * p = (byte *) &XY;
  for (byte i = 0; i < sizeof XY; i++)
    *p++ = Wire.read ();
  haveData = true;
  Serial.println ("I see something!");
I got this from Nick Gammon’s 4th post in this thread:
Ok, I tried another example, one where I’m relying on LED’s instead of println statements to debug whether the I2C is working or not. In addition, I’m also tying the 5V line as well as pin4, pin5, and GND together now. And the two Arduinos are running off the exact same 5V DC adapter, one being powered off the other. But still no joy. The Reader always sees X is 0.
Writer Arduino:
#include <Wire.h>
#define LED_PIN 13
byte x = 0;
  Wire.begin(); // Start I2C Bus as Master
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, LOW);
  Wire.beginTransmission(9); // transmit to device #9
  Wire.write(x);              // sends x
  Wire.endTransmission();    // stop transmitting
  x++;
  if (x > 5) x=0;
  if (x == 0) digitalWrite(LED_PIN, HIGH);
  if (x > 0) digitalWrite(LED_PIN, LOW);
  delay(2000);
Reader/Receiver Arduino:
#include <Wire.h>
#define LED_PIN 13
int x;
  Wire.begin(9);                // Start I2C Bus as a Slave (Device Number 9)
  Wire.onReceive(receiveEvent); // register event
  pinMode(LED_1, OUTPUT);
  pinMode(LED_2, OUTPUT);
  digitalWrite(LED_1, LOW);
  digitalWrite(LED_2, LOW);
  x = 0;
  //If value received is 0 blink LED 1
  if (x == 0) {
    delay(200);
    delay(200);
void receiveEvent(int howMany) {
  x = Wire.read();    // receive byte as an integer
