I am attempting to modify some code I created to take into account different register definitions for an attiny85. I found the following #ifdef in the tiny library so I thought this would work:
#if defined( __AVR_ATtinyX5__ )
WDTCR |= _BV(WDCE) | _BV(WDE); // WDT control register, This sets the Watchdog Change Enable (WDCE) flag, which is needed to set the
WDTCR = _BV(WDIE); // Watchdog system reset (WDE) enable and the Watchdog interrupt enable (WDIE)
#else
WDTCSR |= _BV(WDCE) | _BV(WDE);// WDT control register, This sets the Watchdog Change Enable (WDCE) flag, which is needed to set the
WDTCSR = _BV(WDIE); // Watchdog system reset (WDE) enable and the Watchdog interrupt enable (WDIE)
#endif
However, when I attempt to compile the library using the board="ATtiny85@8MHz (Internal oscillator. BOD disabled)" I get an error message : "home/wandrson/sketchbook/libraries/Entropy/Entropy.cpp:51:3: error: ‘WDTCSR’ was not declared in this scope" which seems to indicate that it is executing the else condition rather than the ATtiny code... I've searched and can't find a reference to what I should find defined for each of the AVR chips... Any suggestions on where I can find that information, or if something is wrong with my syntax above?
AVR_ATtinyX5 is defined by and specific to the Tiny Core...
http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/cores/tiny/core_build_options.h#97
core_build_options.h is also specific to the Tiny Core and disappears in the next version so I suggestion using this...
#if defined( __AVR_ATtiny25__ ) || defined( __AVR_ATtiny45__ ) || defined( __AVR_ATtiny85__ )
CodingBadly:
Thanks for the information. Could you give me a reference to where I could find what macros are defined for what processors, in case I incorporate other processor types. I've search the AVR-LIBC documentation and haven't found any information. Would prefer not to find and grep the source for the library.
wanderson:
I'm not aware of such a reference. I do know that the pattern for the which-processor macro is always the same...
AVR_ATtiny45
Where...
"AVR" is always the prefix
"ATtiny45" is the exact model name from Atmel's documentation
"_" is always the suffix
You will have to consult the datasheet(s) for which processors are in which families. There are no AVR_ATtinyX5 like macros available from AVR-GCC or Libc.
Or did I misunderstand. By "what macros are defined for what processors" do you also mean the "register macros"?
That's the route I've always taken.
