[solved] Indexing a stepper motor & stopping it with home switch in void setup()
Indexing a nema 17 stepper and stopping it with home switch in void setup()
Hi, the code below only works if the flag is already located in the photoelectric sensor when I power on the machine.
However, when I power it on and there is no flag it indexes continuously without stopping even after I insert the flag.
The enaPin should disable the stepper motor based on the driver that I have it connected to so I don't understand what the problem is.
Can someone please help as to why it continuously indexes even after I've inserted the flag into the sensor?
I implemented this based on what I found on the forums
(basically at each step it should check the high/low status of the sensor):
for (int x = 0; x < OneRev && OpticalLimitSwitchValue == LOW; x++)
Plate rotates and stops rotating once it hits photoelectric switch
// defines pins numbers
const int stepPin = 3;
const int dirPin = 4;
const int enaPin = 5;
const int shortPulse = 10;
const int stepIndexInterval = 4000;
const int OpticalLimitSwitch = 2;
const int OneRev = 6400;
  // Sets pins as Outputs
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(enaPin, OUTPUT);
  pinMode(OpticalLimitSwitch, INPUT); // LOW --> No flag , HIGH --> Flag
  digitalWrite(enaPin, LOW);
  digitalWrite(dirPin, HIGH); // Enables the motor to move in a CW direction
  int OpticalLimitSwitchValue = digitalRead(OpticalLimitSwitch);
  if ( OpticalLimitSwitchValue == LOW)
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(shortPulse);                   // most stepper drivers just need a short pulse
      digitalWrite(stepPin, LOW);
      delayMicroseconds(stepIndexInterval);             // this value is the interval between steps
  digitalWrite(enaPin, HIGH);
You need to put the digitalRead() for the limit switch in a loop to constantly check it.
The way you have it now, it checks it once, then continues on, never to check it again.
The simple way to HOME a stepper motor is to move one step and check the limit switch. Repeat as needed.
If the motor is already at the HOME position it would be a good idea to move it away clear of the switch and then home it again.
...R
@evanmars
The issue I have is that I need it to home only once when I power on the machine.
After that I have repetitive cycles in the void loop () function and I want to avoid homing every cycle step.
@Robin2
Isn't this checking every step?
I will attempt to do this with the code below and try it out right now:
  for (int x = 0; x < OneRev; x++)
    if (OpticalLimitSwitchValue == LOW)
knightridar:
No. You need a digitalRead() to get the value
...R
I did include this before the for loop:
I tried the latest code below but I get the same situation.
It simply does not stop moving when I insert a flag into the sensor.
If I have the flag already inserted before startup it doesn't move after I remove the flag.
(this makes sense to me).
I wanted to keep things simple for this specific problem, but here is the full scenario:
Cycle steps:
  1. Machine powered on
  2. Index plate rotates once until it reaches home switch and then stops
This should happen continuously in loop:
  1. Two capacitive sensors are touched
  2. Stepper motor rotates 90 degrees
  3. Solenoid activates
  4. Solenoid deactivates
Full code for reference:
  Cycle steps:
  3. Two capacitive sensors are touched
  4. Stepper motor rotates 90 degrees
  5. Solenoid activates
  6. Solenoid deactivates
  Microsteps Wanted = (Wanted Angle/360) * Driver Micro Steps Setting
const int shortStopPulse = 0;
const int stepInterval = 1000;
// When Sig Output is high, touch sensor is being pressed
#define CapacitiveTouchSensorLeft 11 // Pin for capacitive touch sensor
#define CapacitiveTouchSensorRight 12
const int IndexRev = 1600; //6400 pulses in revolution, 1600 pulses equal 25% revolution
int led = 13; // pin for the LED
int SolidStateRelay = 10; // pin for Solid State Relay
  pinMode(CapacitiveTouchSensorLeft, INPUT);
  pinMode(CapacitiveTouchSensorRight, INPUT);
  pinMode(led, OUTPUT);
  pinMode(SolidStateRelay, OUTPUT);
  digitalWrite(led, LOW);
  digitalWrite(SolidStateRelay, LOW);
  Serial.println("Solenoid Inactive");
  int CapacitiveTouchSensorLeftValue = digitalRead(CapacitiveTouchSensorLeft);
  int CapacitiveTouchSensorRightValue = digitalRead(CapacitiveTouchSensorRight);
  if (CapacitiveTouchSensorLeftValue && CapacitiveTouchSensorRightValue == HIGH)
      // Makes pulses for making 90 degree rotation
      for (int x = 0; x < IndexRev; x++)
        delayMicroseconds(stepInterval);             // this value is the interval between steps
      digitalWrite(led, HIGH);
      digitalWrite(SolidStateRelay, HIGH);
      Serial.println("Solenoid Activated");
      delay(2000);
      Serial.println("Solenoid Deactivated");
      delay(2000);
I tried to do this, but it still didn't stop the indexer from rotating upon power up:
inserted this in between the stepper timings
OpticalLimitSwitchValue;
However, I know that this loop is being processed faster than I can react to insert a flag into the sensor.
I need to figure out how I can include it in a loop such that it will not constantly go to the home switch every time I run a cycle operation listed below. So somehow it needs to loop but only run once when I start up the machine. I'm wondering if adding a counter will help.
knightridar:
That's not much good when it should be inside the loop. digitalRead() does not keep updating itself - it only works once for each time it is called.
...R
Thanks so much!
I was unaware of this.
That fixed it.
For reference if anyone wants to use it.
Now I'll try to implement with Accelstepper library.
const int stepIndexInterval = 16000; // longer interval --> slower RPM
    uint8_t OpticalLimitSwitchValue = digitalRead(OpticalLimitSwitch);
