This sketch wil not compile becourse the int count is not decleared in this function. To solve this I made it static but still it wont compile, why??
#include <LiquidCrystal.h>
/* ==== PINS ASSIGNMNET ==========
LCD RS pin to digital pin 8
LCD EN pin to digital pin 9
LCD D4 pin to digital pin 4
LCD D5 pin to digital pin 5
LCD D6 pin to digital pin 6
LCD D7 pin to digital pin 7
Backlight PWM control to Pin 10
LCD R/W pin to ground
// Set the I/O pin for LCD 4-bit mode following the library assignment:
// LiquidCrystal(rs, en, d4, d5, d6, d7).
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int btnPIN = A0; // select the input pin for the keypad
int lcd_key = 0;
int adc_key_in = 0;
static int count = 0;
int btnNow = 0;
int btnPrev = 9;
int addCnt = 0; // value added to count
static unsigned long tmrPrev1 = 0;
static unsigned long tmrPrev2 = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(btnPIN); // read the value from the sensor
// button value's measured
//select = 720
//up = 131
//down = 308
//left = 480
//right = 0
//none = 1023
// I add approx 50 to those values and check to see if we are close
if (adc_key_in > 1500) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 500) return btnLEFT;
if (adc_key_in < 770) return btnSELECT;
return btnNONE; // when all others fail, return this...
tmrPrev1 = millis();
tmrPrev2 = millis();
if ( (millis() - tmrPrev1) >= 800UL) {
btnNow = read_LCD_buttons();
addCnt = 1;
process_key();
Serial.print(count);
Serial.print(" -- ");
Serial.print(btnNow);
Serial.print(" -2- ");
Serial.println(millis() / 1000);
// do something wiht this info
if ( (millis() - tmrPrev2) >= 5000UL) {
addCnt = 10;
process_key();
void process_key() {
switch (btnNow) {
case btnRIGHT:
case btnUP:
count += addCnt;
case btnDOWN:
count_ = addCnt;
case btnLEFT:
case btnSELECT:
