[Solved] Integer Math Help
I'm a bit rusty from my CS151 class...
Remind me the proper way of doing this:
I'm using a voltage divider with a potentiometeron A1 to determine a volume level. Using analogRead() I will get an int between 0-1023.
I have an alarm circuit connected to A0. Using analogWrite() I can input a value between 0-255.
Basically I need to do analogRead/4. If I am storing those variables as ints will it automatically do all the rounding that needs to be done. How about in the case of 1023/4 = 255.75? Do I need to use an if/then to keep that at <255?
By default, there is no rounding, only truncation, so it isn't a worry.
It is simple to check boundary conditions like this on the actual hardware if your not sure.
  Serial.print("1023/4=");
  Serial.println(1023/4);
produces
1023/4=255
