[SOLVED] Interfaces like in Java?
I am searching for something like an interface in java but i don't know how to do it.
I've tried this but with no success:
class Test1 {
  public:
    virtual void test1();
class Test2 : public Test1 {
  public:
    void test1() {
      Serial.println("test");
  Test1 test = Test2();
  test.test1();
when i tried to compile i got this:
C:\Users\schnu\AppData\Local\Temp\cc7qsv4w.ltrans0.ltrans.o: In function `Test1::Test1(Test1&&)':
C:\Development\Arduino\Test/Test.ino:1: undefined reference to `vtable for Test1'
C:\Users\schnu\AppData\Local\Temp\cc7qsv4w.ltrans0.ltrans.o: In function `setup':
C:\Development\Arduino\Test/Test.ino:16: undefined reference to `Test1::test1()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Pro or Pro Mini.
Is there any way to do it?
You have to create an instance of the class:
class Test1 {
  public:
  public:
    void test1() {
Test2 instanceOfTest2;
  instanceOfTest2.test1();
But how can I call the method in class that extends Test1 without knowing the class?
You can call the virtual method of any derived class by using a pointer to the base class:
class Test1 {
  public:
    virtual void test1() = 0;  // Make this interface purely virtual
  public:
    void test1() {
Test1 *basePointer = &instanceOfTest2;
  basePointer->test1();
It works! Thanks!
I am new here, should i mark this post as something and if yes how?
You can change the title to included "[SOLVED]".
BTW, consider the example here: array of objects - #7 by gfvalvo - Programming Questions - Arduino Forum
