[SOLVED]:invalid conversion from 'const char*' to 'char*' [-fpermissive]
Hi guys !;thanks for read this.
I found this code for cs1302 clock,
https://create.arduino.cc/projecthub/eri...lay-6e1035
in this part he define next variables:
const char * DS1302ErrorMessage = "*RTC ERROR";
const char * AM2320ErrorMessage = "*TEMPERROR";
and a function:
void powerOnTest() {
  Time t = rtc.time();
  if (dayAsString(t.day) == DS1302ErrorMessage ) {
      displayStringCondensed(0, DS1302ErrorMessage);
  switch(th.Read())
    case 1 or 2:
      displayStringCondensed(0, AM2320ErrorMessage);
everything looks nice, however always appears this message
C:\Users\xinal\Documents\Arduino\maxclock\MAXCLOCK_PRUEBA\MAXCLOCK_PRUEBA.ino: In function 'void powerOnTest()':
C:\Users\xinal\Documents\Arduino\maxclock\MAXCLOCK_PRUEBA\MAXCLOCK_PRUEBA.ino:156:51: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
C:\Users\xinal\Documents\Arduino\maxclock\MAXCLOCK_PRUEBA\MAXCLOCK_PRUEBA.ino:280:6: note:   initializing argument 2 of 'void displayStringCondensed(int, char*)'
 void displayStringCondensed (int startCol, char * displayString) {
C:\Users\xinal\Documents\Arduino\maxclock\MAXCLOCK_PRUEBA\MAXCLOCK_PRUEBA.ino:161:51: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
Would you help me to understand why appears this plase?
Neodimio58:
You didn't include all the code, but I'm gonna guess because the signature for the function 'displayStringCondensed()' defines its second parameter as type 'char *'. Does this function need to change the string that this parameter is pointing to? If not, change its type to 'const char *'.
Hi gfvalvo.
Thanks a lot for your time answering me. Wow !! you´re the law
this is original function.
  int i;
  char c;
  destMatrix = 0;
  destCol = 7 - startCol;
  for (i = 7; i > (7 - startCol); i--)                      // clear first columns if the startCol > 0
    lc.setColumn(destMatrix, i, B00000000);
  while (displayString[0] != 0) {
    c = displayString[0];
    if (destMatrix == 4 || displayString[0] == '~') {       // next line when we're out of matrices or a newline character is sent: ~
      clearLastColumns();
      destMatrix = 0;
      if (displayString[0] == '~') {
        displayString++;
      delay(nextLineDelay);
    if (displayString[0] == '|') {                          // display one blank column
      lc.setColumn(destMatrix, destCol, B00000000);
      increaseColCounter();
    else if (displayString[0] == '.') {                     // display a point in a single column
      lc.setColumn(destMatrix, destCol, B10000000);
    else if (displayString[0] == '!') {                     // display a !
      lc.setColumn(destMatrix, destCol, B10111111);
    else if (displayString[0] == '/') {                     // display a % sign, % sign won't work because of the snprintf function
      lc.setColumn(destMatrix, destCol, B11000011);
      lc.setColumn(destMatrix, destCol, B00110011);
      lc.setColumn(destMatrix, destCol, B11001100);
    else if (displayString[0] == '*') {                     // display a *
      lc.setColumn(destMatrix, destCol, B00100010);
      lc.setColumn(destMatrix, destCol, B00010100);
      lc.setColumn(destMatrix, destCol, B01111111);
    else {
      if (destMatrix == 3 && destCol < 4) {                 // the character does not fit so enforce a new line
        clearLastColumns();
        destMatrix = 0;
        displayString--;
      else {
        int pos = lc.getCharArrayPosition(c);
        for (i = 0; i < 6; i++) {
          lc.setColumn(destMatrix, destCol, alphabetBitmap[pos][i]);
    displayString++;
  clearLastColumns();
after changing
void displayStringCondensed (int startCol, const char * displayString)
code runs smoothly! Thanks again; I promise study hard to one day helps in this forum like you! :slight_smile:
