(Solved) ir remote relay control
i am trying to control 4 relays using a ir remote control. i successfully can control 1 of the relays by pressing any button i program the arduino pin to respond to. press the button once, turns pin on, press the same button again, turn the pin off. i need help writing a sketch to control 4 arduino pins, each with their own button on the ir remote. help would be great. thank you
#include <IRremote.h>
int RECV_PIN = 11;
int relay1 = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
  pinMode(relay1, OUTPUT);
  pinMode(13, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
int on = 0;
unsigned long last = millis();
  if (irrecv.decode(&results)) {
    if (results.value == 0xF171) { // Remote Control Power Code
      // If it's been at least 1/4 second since the last
      // IR received, toggle the relay
      if (millis() - last > 250) {
        on = !on;
        digitalWrite(relay1, on ? HIGH : LOW);
      last = millis();
    irrecv.resume(); // Receive the next value
What is the problem?
Isn't it working if you do...
else if (results.value == WHATEVER) {
    on2 = !on2;
    digitalWrite(relay2, on2 ? HIGH : LOW);
  last = millis();
Also a little tip, change:
int relay1 = 4;
int on = 0;
on = !on;
to
byte relaysPins[] = { 4, 5, 6, 7 }; //assuming relays are connected to those pins...
bool relaysStates[] = { LOW, LOW, LOW, LOW };
relaysStates[0] = !relaysStates[0];
digitalWrite(relaysPins[0], relaysStates[0]);
etc... Well, only a suggestion :wink:
i’m not really sure how to use that type of sketch set up, this ir stuff has me baffled too. i tried the else if once before and it didn’t work but now i got it working except after i turn on any of the 4 relays i can turn on and off the first relay with a single button press but after it on, turning on the other 3 takes two button presses just to turn on. i’m pretty sure its miss placement of the irrecv.resume(); command but i’m not really sure where i need to put it. i tried putting it at the end of every (else if) statement but then the whole thing doesn’t work. where i have it in this code is the only way i found so far that gives me close to perfect output results
int RECV_PIN = 11;
int relay1 = 2;
int relay2 = 3;
int relay3 = 4;
int relay4 = 5;
  pinMode(relay4, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay2, OUTPUT);
int on = 0;
        on = !on;
      last = millis();
  else if (results.value == 0xF1B1) {
    on = !on;
    digitalWrite(relay2, on ? HIGH : LOW);
  last = millis();
else if (results.value == 0xF1A1) {
    on = !on;
    digitalWrite(relay3, on ? HIGH : LOW);
  last = millis();
else if (results.value == 0xF121) {
    on = !on;
    digitalWrite(relay4, on ? HIGH : LOW);
  last = millis();
If you put each { on a new line, and use Tools + Auto Format, you'll see that you have inserted the new if statements and block in the wrong place. They should be between the lines:
and
is this what you meant? it didn’t affect my arduino
int RECV_PIN = 11;
int relay1 = 2;
int relay2 = 3;
int relay3 = 4;
int relay4 = 5;
int on = 0;
    if (results.value == 0xF171) // Remote Control Power Code
        on = !on;
      last = millis();
      on = !on;
    last = millis();
      on = !on;
    last = millis();
      on = !on;
    last = millis();
It's what I meant by putting each { on a new line and formatting. You did not move the added code into the right place, though.
      on = !on;
    last = millis();
and the similar blocks after it need to go BEFORE
You may well need to have different time and state variables for each button, too. It seems that you maybe want to prevent multiple presses of the same button within a specified period, but you should, I think, be able to press different buttons in that same period.
i can press one of the buttons over and over and the relay will turn on and off like it should with every press of the button but when i press the next button (even if i wait several seconds before i press it) it still takes two presses. now if i keep pressing the same button i just pushed it will work just fine. it takes two presses the first time i switch to a different button that corresponds to a different relay
also if i turn the relay on then back off then move on to a different relay it works just fine without having to push the button twice
Maybe because you use the same "on" variable for every relays..? So do like in my first post, an array to hold state of each relay, or create other variables "on2", "on3" if you find it easier :slight_smile:
you sir, are a genius. that on2 on3 thing worked…thank you much
int RECV_PIN = 11;
int relay1 = 2;
int relay2 = 3;
int relay3 = 4;
int relay4 = 5;
int on = 0;
int on1 = 0;
int on2 = 0;
int on3 = 0;
        on = !on;
      last = millis();
        on1 = !on1;
        digitalWrite(relay2, on1 ? HIGH : LOW);
      last = millis();
        on2 = !on2;
        digitalWrite(relay3, on2 ? HIGH : LOW);
      last = millis();
        on3 = !on3;
        digitalWrite(relay4, on3 ? HIGH : LOW);
      last = millis();
Hehe, glad to help :slight_smile:
you sir, are a genius. that on2 on3 thing worked...thank you much
Wasn't that what I said in Reply #5?
oh i'm sorry i'm pretty new at this stuff so i didn't quite understand what you meant i guess, he drew it out in crayon for me
Hi
Im new to arduino, Im also working on same theme but with a diff code, the code works but the result is nor stable
can any one help
Im trying to switch on and off an led with a same button, Im using a sony remote
int LED1 = 13;
int on = 0;
int RECV_PIN = 11;
    Serial.println(results.value, DEC);
  switch(results.value)
    case 16:
    on = !on;
    digitalWrite (LED1, on ? HIGH : LOW);
You'll need to explain what this means. We can't see what you are observing as unstable.
I have assign button # 1 (Sony remote) to turn on/off the LED on pin 13
it works fine but some times the remote button is pressed for longer period and sometimes for short period
the IR receiver continuously receive signal from the remote, now when i press the remote button for a longer period it receives 3 to 5 signals and 2 to 3 signals when button is pressed for short period
like it receives
16 ----> ON
16 ----> OFF
16 ----> ON
16 ----> OFF
result is OFF
when the signal is received 3 times like
16 ----> ON
16 ----> OFF
16 ----> ON
result is ON
I want the receiver to receive signal only once if I press the remote button for a longer or shorter period
Hello and welcome Wiki,
First, just so you know, this:
Could be changed to this:
digitalWrite (LED1, on);
It's the same thing (but then I suggest renaming "int on" to "bool LED1_state" or something like that :slight_smile:
Then, to solve your problem, study this code: https://github.com/shirriff/Arduino-IRremote/blob/master/examples/IRrelay/IRrelay.ino
And next time, start your own topic :slight_smile:
