(Solved) ir remote relay control
is this what you meant?
It's what I meant by putting each { on a new line and formatting. You did not move the added code into the right place, though.
  else if (results.value == 0xF1B1)
    if (millis() - last > 250)
      on = !on;
      digitalWrite(relay2, on ? HIGH : LOW);
    last = millis();
and the similar blocks after it need to go BEFORE
    irrecv.resume(); // Receive the next value
You may well need to have different time and state variables for each button, too. It seems that you maybe want to prevent multiple presses of the same button within a specified period, but you should, I think, be able to press different buttons in that same period.
