[SOLVED] IR Sensor Value Help
Hi, I'm first time working on Arduino for my project and I ran into an issue. I'm trying to make a very simple Vending Machine. Coin or any obstacle passes in front of the IR sensor and based on that, the user can either press button 1 or 2 and based on that motor 1 or 2 would run respectively. The overall logic works exactly how I want it to, the issue I'm facing is that the IR sensor only lets me press the buttons as long as something is continuously in front of the IR sensor. I want the IR sensor to keep the value once the obstacle passes in front of it and keep the value until a button is pressed. I can't seem to come up with a solution.
const int relayControl1_1 = 13; // relay 1 of 1 (input 1)
const int relayControl1_2 = 12; // relay 1 of 2 (input 2)
const int relayControl2_1 = 11; // relay 2 of 1 (input 3)
const int relayControl2_2 = 10; // relay 2 of 2 (input 4)
const int inButton1 = 9; //input button 1
const int inButton2 = 8; //input button 2
int buttonStatus1 = 0;
int buttonStatus2 = 0;
const int inSensor = 7;
  pinMode(relayControl1_1, OUTPUT);
  pinMode(relayControl1_2, OUTPUT);
  pinMode(relayControl2_1, OUTPUT);
  pinMode(relayControl2_2, OUTPUT);
  pinMode(inButton1, INPUT_PULLUP);
  pinMode(inButton2, INPUT_PULLUP);
  pinMode(inSensor, INPUT_PULLUP);
  int sensorStatus = digitalRead(inSensor); //this is where the input is taken from the Sensor
  if(sensorStatus == LOW) {
      buttonStatus1 = digitalRead(inButton1);
      if(buttonStatus1 == HIGH) {
        digitalWrite(relayControl1_1, LOW);
        digitalWrite(relayControl1_1, HIGH);
      buttonStatus2 = digitalRead(inButton2);
      if(buttonStatus2 == HIGH) {
        digitalWrite(relayControl2_1, LOW);
        digitalWrite(relayControl2_1, HIGH);
The solution is for your program to remember the value, not the sensor. The program can remember the value when you save it in a variable.
Paul
The input from the sensor is being stored in sensorStatus variable but it still isn't working.
if (digitalRead(inSensor) == LOW) sensorStatus = LOW; // sets the sensorState
Reset the sensorStatus to HIGH after you're done with the buttons and relay switching.
Leo..
I did what is described above and now I'm having a new issue. The sensorStatus doesn't seem to be mattering anymore. The buttons seem to be working whether anything passes by the sensor or not.
For example, I upload the code to the Arduino and I didn't pass anything by the sensor and pressed the button and the motors rotate anyways.
  int sensorStatus;
      sensorStatus = HIGH;
PS: Sorry for the late reply, I got busy because of my exams.
I was able to find solutions:
1 - int sensorStatus; should have been set to static int sensorStatus = HIGH; to make the program remember the value of the sensor.
2 - sensorStatus = HIGH; should have been right after digitalWrite(relayControl1_1, HIGH); in the buttonStatus conditional else part to make the program set the sensorStatus back to HIGH correctly.
3 - Unrelated to the question posted, doing the above steps made the program run the motors continuously unless they were stopped by an obstacle from the IR sensor. This was fixed by adding delay(2000); digitalWrite(relayControl1_1, LOW); after the sensorStatus = HIGH; mentioned in the 2nd step.
Source Code after the solution:
  if (digitalRead(inSensor) == LOW) {
    sensorStatus = LOW;
        delay(2000);
        delay(2000);
