hey so i'm doing a project at the moment and I'm trying to use the IRremote function but its giving me this error
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\IRremote-2.2.3\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
I'm using a nano
and i have my buzzer connect to pin 5 as to below
already did the fix of doing this
// Arduino Duemilanove, Diecimila, LilyPad, Mini, Fio, Nano, etc
// ATmega48, ATmega88, ATmega168, ATmega328
#define IR_USE_TIMER1 //tx = pin 9
//#define IR_USE_TIMER2 // tx = pin 3
#endif
but its still giving me the same error
is there anything else im missing?
file code
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include <ir_Lego_PF_BitStreamEncoder.h>
IRsend irsend;
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 3; // the number of the LED pin
const int buzzer = 5; // pin for the buzzer
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
pinMode(buzzer, OUTPUT);
int blah = 0;
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
irsend.sendNEC(0x80C, 32);
delay(40);
tone(buzzer,1000);
Serial.print("on ");
Serial.println(blah);
blah++;
else {
// turn LED off:
digitalWrite(ledPin, LOW);
Serial.println("Switch is not pressed");
testing.ino (969 Bytes)
