SOLVED: Is my SIM900A GSM-Modem SIM/Subscriber-locked ?
Hi!
I've made a carrier board for a brand new SIM900A GSM Module. The board works perfectly (first try :smiley: )
A pic: Dropbox - Error
BUT, i cannot register on the GSM network with it :~
I've bought it from an Aliexpress-seller, so no product support :-/
When PIN on the SIM-card is disabled, it will respond like this:
AT+CPIN?
+CPIN: PH-NET PIN
As far as I can find out via Data sheets/Google, PH-NET PIN means that the module is locked to a specific vendor of SIM/Network :fearful:
When pulling the SIM and enabling the PIN-code on a cellphone, putting it back gives me this:
AT+CPIN?
+CPIN: SIM PIN
OK
AT+CPIN="1889"
OK
AT+CPIN?
+CPIN: PH-NET PIN
So, the same result.
Iv'e tried with two different SIM-cards, one for each of the big networks here in Denmark (Tele Denmark & Telenor)
Does anyone here have any ideas of what I could try, before pulling out more hair on my head ? :~
Thanks!
// Per.
I've asked on the mailing list of my Local hackerspace, and we have it figured out now.
The SIM900A model is for the chinese market and some others, see list:
So AVOID the 900A model unless you are in one of these countries !
I have ordered some non-A models now :slight_smile:
// Per.
I just face the same problem and I found some interesting informations : it seams you can deal with this problem by uploading a new firmware on the sim900a
check these 2 links, you will get more details on how to do :
I'll test tomorrow an let you know if I succeed or not
