[Solved] Issue in String to Char array conversion
Hi guys. I’m working in a project that i need to send strings trhough RF. But, to be able to do this I have to convert the string that I want to a char array, becouse of the library.
So, partialy the code that I’m using is this
#include <Wire.h>
#include <math.h>
#include <Adafruit_MCP4725.h>
#include <PID_v1.h>
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver;
char RF_msg[30];
String msg;
Adafruit_MCP4725 dac; // constructor
#define ThermistorPIN1 0   // Analog Pin 0
#define ThermistorPIN2 1
double temp1, temp2;
double Volts = 0, Power = 0, dac_volts;
float temp_media[10];
//Def PID variables and parameters
double Setpoint, Input, Output;
//kp=80, ki=7, kd=9
double Kp = 188.7093, Ki = 14.5407, Kd = 363.5954;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
 dac.begin(0x62);
 //turn the PID on
 myPID.SetOutputLimits(574, 4095);
 myPID.SetMode(AUTOMATIC);
 //pre_set();
 Serial.println("start");
  temp1 = Thermistor(analogRead(ThermistorPIN1));
  temp2 = Thermistor(analogRead(ThermistorPIN2));
  double in = analogRead(2);
  Volts = (in*5/1023)/0.204;
  Power = (Volts*Volts)/10;
  Setpoint = temp2;
  Input = temp1;
  myPID.Compute();
  dac.setVoltage(Output, false);
  dac_volts = (5.0/4095.0)*Output;
  Send_RF_Msg();
  delay(100);
void pre_set(){
  Setpoint = 40;
  long int t0 = millis();
  while(1){
    Serial.println(temp1);
    //Serial.print(" ");
    Input = temp1;
    myPID.Compute();
    if (millis()-t0 >= 300000){
void Send_RF_Msg(){
  msg.concat(temp1);
  msg.concat('-');
  msg.concat(temp2);
  msg.concat('-');
  msg.concat(Power);
  msg.concat('-');
  msg.concat(Output);
  msg.toCharArray(RF_msg, sizeof(msg)+1);
 Serial.println(RF_msg);
 driver.send((uint8_t *)RF_msg, strlen(RF_msg));
 driver.waitPacketSent();
 msg = "";
But, I’m not geting in the Serial output the whole message, just the first part. For example, the complety string is: “48.17-48.52-4.87-1023.00”, and the code just prints “48.17-”.
Any clues?
Ps: When i try to print the string in the variable msg, the arduino prints the whole message.
Please post your code
OK, I edited the post, there is just a second archive that contains the resistence/temperature conversion.
What string type is used for msg?
I edited it to use a c string function, include <stdio.h>, try this and see if it works.
  sprintf(RF_msg, "%f.2-%f.2-%f.2-%f.2", temp1, temp2, Power, Output);
sizeof(msg) - it may surprise you.
May surprise Obrazi that %f isn't supported on Arduino.
What a shame, thanks AWOL. I was just using the sizeof() in a wrong way, I just replaced it for msg.lenght() and it worked.
Delta_G: May surprise Obrazi that %f isn't supported on Arduino.
It did.
