Hi all,
Thank you for reading this again. The code posted here is an MRE of a much larger code.
Goals:
- Create an arbitrary array with 10 elements, each of which is the following 10-bit integer: 0000000000.
- Change the first 6 members of this array to 0000000100.
- Write the "non-0000000000" members of this array into an SD card.
Code:
#include <SD.h>
File myFile;
int intermDataLog [10];
void setup () {
pinMode (53, OUTPUT);
SD.begin (53);
for (int i = 0; i <= 9; i++) {
intermDataLog [i] = (0 << 9);
for (int i = 0; i <= 5; i++) {
bitWrite (intermDataLog [i], 2, 1);
myFile = SD.open ("testing.txt", FILE_WRITE);
if (intermDataLog [i] != (0 << 9)) {
for (int ii = 9; ii >= 0; i--) {
myFile.print (bitRead (intermDataLog [i], ii));
myFile.print ("\n");
myFile.close ();
void loop () {
Reality:
The SD card reader's "activity" LED keep going on and off in a seemingly infinite loop. When I take out the SD card, a file with the desired file title is created, but it's empty.
Please let me know if I need to provide anything else. Thank you again.
did you mean
intermDataLog [i] = (1 << 9);
also
Did you mean to decrement 'i' or 'ii' in the last line there?
aarg:
did you mean
Thank you for your response. Wouldn't that make intermDataLog [eye] = 1000000000?
My goal is for it to be 0000000000.
ArianKS:
The compiler initializes global variables to 0. To make it 00000000, you just:
intermDataLog [i] = 0;
is the same as
Example for the first element:
intermDataLog [0] = (1 << 3);
Hint: "non-zero" array element can be detected as simply as
if (intermDatalog[i]) do_something();
Thank you all. I've added your suggestion—and for the sake of simplicity, I'm using Serial instead of SD here. The issue still remains unsolved:
Code:
void setup () {
Serial.begin (9600);
while (!Serial) {
intermDataLog [i] = 1000000000;
if (intermDataLog [i] != 1000000000) {
Serial.print (bitRead (intermDataLog [i], ii));
Serial.print ("\n");
void loop () {
Serial monitor output:
The number of '⸮' keeps on increasing horizontally.
an int is only 16 bits long on Arduinos
an int can only be between −32,768 and 32,767
intermDataLog = 1000000000; will not work.....
I think what you're after is
intermDataLog = 0b1000000000;
the 0b is telling the compiler that the number after it should be interpenetrated as binary number
instead of 1 billion.
Hi all—it's fixed. Thank you so much, I learned a lot!
Oops.
jremington:
Oops.
Yep, one of the beauties of my life.
5 hours basically wasted.
ArianKS:
Welcome to the life of a software developer
It happens to all of us at times no matter how many years we've been doing it.
