[SOLVED] Issues with SD.h and ESP8266
I've tried to compile the read/write example in the Arduino IDE using the Wemos D1 Mini.
When I try to compile it, it stops and throws an error pointing to if (!SD.begin(CS_PIN)).
#include <SPI.h>
#include <SD.h>
File myFile;
#define CS_PIN D8
  Serial.print("Initializing SD card...");
  if (!SD.begin(CS_PIN)) { <====== THROWS ERROR
    Serial.println("initialization failed!");
    return;
The error is:
cannot convert 'SPISettings' to 'uint32_t' {aka 'unsigned int'}
Yet I've used SD.h on my Wemos d1 Mini's in the past without issue.
Any help would be appreciated.
You are missing one more closing brace, "}", at the end of your code.
#include <SPI.h>
#include <SD.h>
File myFile;
#define CS_PIN D8
    return;
#include <SPI.h>
#include <SD.h>
File myFile;
#define CS_PIN D8
void setup() {         <== void brace start
  if (!SD.begin(CS_PIN)) {          <== if brace start
    return;
  }       <== if brace end
}         <== void brace end
I don't see any missing braces. If there were I would have been thrown a different error.
But thanks for trying ruilviana.
For what it's worth, the code compiles fine for an Arduino Uno board. Just not for an ESP8266 board.
UPDATE:
I switched to my laptop and the code compiles fine on it for the ESP8266 board, just not on my desktop computer. Strange.....
UPDATE #2:
I found a library that was conflicting with the call to SD.h
Removed the library sdFat.h and everything compiled fine.
Marked as solved.
