[SOLVED] "LCM1602 IIC A0 A1 A2" (+OTHERS) I2C Controller working with 20x4 LCD
UPDATE: This page on the http://ArduinoInfo.Info WIKI has library information and example code for 3 versions of I2C Backboards:
http://arduino-info.wikispaces.com/LCD-Blue-I2C
This covers display adapter backboards marked:
“YwRobot Arduino LCM1602 IIC V1”
“Arduino-IIC-LCD GY-LCD-V1”
“LCM1602 IIC A0 A1 A2”
That last one was new to me. It’s Yet Another variation on the little I2C backpack boards for 16x2 and 20x4 LCD displays.
This one has address 0x20 (The A0, A1, A2 pins are grounded by solder bridges). Here’s a Photo:
BUT the internal wiring from the PCF8574T is different and must be handled in Setup.
Software/Library setup was nicely written up by Gordon Shumway in another post, so I’ll steal it here:
Step 1: Remove all LCD libraries from your Arduino IDE. Check both the user specific ones, as well as in the Arduino install folder. Zip them up and save them somewhere else if you think you might need them again, otherwise, delete.
Step 2: Install the new and improved LCD library by F Malpartida from here: https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home This person has done some awesome work for the Arduino community.
And here’s the code that works, with the connections fixed in the #defines for the I2C chip to Display connections. Phew!
/* YourDuino.com Example Software Sketch
 20 character 4 line I2C Display
 ANOTHER NEW TYPE Marked "LCM1602 IIC  A0 A1 A2"
 A0-A1-A2 are grounded so I2C Address is 0x20
 terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>  // F Malpartida's NewLiquidCrystal library
//Download: https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move original LiquidCrystal library elsewhere, copy this in it's place
/*-----( Declare Constants )-----*/
#define I2C_ADDR    0x20  // Define I2C Address for the PCF8574T
//---(Following are the PCF8574 pin assignments to LCD connections )----
// This are different than earlier/different I2C LCD displays
#define BACKLIGHT_PIN  3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
#define  LED_OFF  1
#define  LED_ON  0
/*-----( Declare objects )-----*/
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
void setup()   /*----( SETUP: RUNS ONCE )----*/
  lcd.begin (20,4);  // initialize the lcd
// Switch on the backlight
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(LED_ON);
}// END Setup
void loop()   /*----( LOOP: RUNS OVER AND OVER AGAIN )----*/
// Reset the display
  lcd.clear();
  lcd.home();
// Print our characters on the LCD
  lcd.backlight();  //Backlight ON if under program control
  lcd.setCursor(3,0); //Start at character 3 on line 0
  lcd.print("Hello, world!");
  lcd.setCursor(2,1);
  lcd.print("From YourDuino");
  lcd.setCursor(0,2);
  lcd.print("20 by 4 Line Display");
  lcd.setCursor(0,3);
  delay(2000);
  lcd.print("http://YourDuino.com");
  delay(8000);
} // END Loop
Thanks to F Malpartida for saving us all a LOT of work, and to Nick Gammon for his I2C scanner!
Terry, Where is that example/sample code from? (I'd really like to get it updated)
While setBacklight() works for this device, I would discourage it's use to turn on/off the backlight as it is used to set an intensity not just for on/off control. On devices such as this that do not support backlight dimming, any non zero value will turn the backlight full on, but on devices that support dimming like when 4bit mode is used, setting the backlight intensity to 1 will be very dim. If backlight on/off control is desired, then backlight() noBacklight() calls would be the preferred method as those will work on any device that has backlight control and will result in full on or full off.
fm's latest library allows setting the backlight bit and polarity in the constructor as well as turns on the backlight in begin() for all device interfaces. This can simplify the setup code in the sketch so that it can be the same regardless of the interface (i2c, SR, 4bit, etc...) All you have to do is setup the full constructor, then, the begin() handles everything else regardless of the underlying interface to the LCD. This allows the actual setup() sketch code to be consistent and the same for all interfaces. i.e. if you change from i2c to 4bit, all that changes is the constructor. The sketch code does not have to change.
So for example:
#define BACKLIGHT_POL POSITIVE // POSITIVE or NEGATIVE depending board design
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin, BACKLIGHT_PIN, BACKLIGHT_POL);
  lcd.begin (20,4);  // initialize the lcd, also turns on backlight
}// END Setup
--- bill
Hi I bought 3 of these "LCM1602 IIC" things with the hope I can use the 3 of them in one arduino. It was a difficult task to get them work until I got to http://arduino-info.wikispaces.com/LCD-Blue-I2C.
The bad news was they ALL have address 0x20 , so I see the same info in the 3 20x4 LCD Displays ( 2004). Is there a way to change the address to 2 of these 3 circuits?.
thnx
fedekrum: The bad news was they ALL have address 0x20 , so I see the same info in the 3 20x4 LCD Displays ( 2004). Is there a way to change the address to 2 of these 3 circuits?.
If they are the same as Terry's image in the first post then removing the solder bridge(s) on A0, A1 or A2 so all three LCD's have different combinations should change the address. Remove a bridge and then use a I2C scanner to check the address has changed.
Yes, is the one that says "LCM1602 IIC A0 A1 A2" I did remove a0 and a2 and gives me de same address, 0x20. Any Clue?
fedekrum: Yes, is the one that says "LCM1602 IIC A0 A1 A2" I did remove a0 and a2 and gives me de same address, 0x20. Any Clue?
Strange, can you post a picture of A0-A2 pins you have cleared. It should have worked unless there is also a trace to cut under the solder bridge.
Hi, I'll be testing this soon... I plan to update the ArduinoInfo.Info WIKI with photos of the variants.
Two things vary: I2C address (usually 27 or 20) AND pinout of the I2C chip to the LCD pins.
@bperrybap My apologies for not seeing you post on the proper changes to the examples! I'll do that and post back here...
Hi, Bill, I have redone and tested all the examples using the FM library only. I'm glad to remove that source of confusion for users.
The update page is here: http://arduino-info.wikispaces.com/LCD-Blue-I2C
I THINK I have the constructor/init right. Please comment!!
Cool!
The constructors look good.
There is a remaining call to
lcd.setBacklight(HIGH);  // HIGH or LOW
in the second example. oops…
One thing that might be useful for folks is to show them how to control
the backlight in the examples.
Maybe extend the comment for the begin() calls?
  lcd.begin(20,4);         // initialize the lcd for 20 chars 4 lines, turn on backlight
Might be interesting to add this code or something similar
somewhere in setup() for a quick demo of backlight control?
		 * Quick 3 blinks of backlight
		for(int i = 0; i< 3; i++)
			lcd.backlight();
			delay(250);
			lcd.noBacklight();
			delay(250);
		lcd.backlight(); // finish with backlight on
As you have seen, some backpacks have a jumper installed on it that can affect backlight control.
Since some jumpers permanently enable the backlight on and some permanently disable the backlight to off,
this small test will allow users to tell if their backlight circuit is working and figure out how they
want to set their backlight jumper (if they have one).
— bill
Just noticed one other thing. The i2c address in the comment in the last example doesn’t match the constructor
Not sure which is correct:
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x20, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
— bill
I have taken a picture. Find it atached. This is still giving me 0x20.
fedekrum, The photo you supplied appears to show all 3 solder jumpers removed. Are saying that when you solder across any of the A0, A1, A2 lines the address does not change?
Hi Bill, Good on the pointers; I'll update those. (Did first 2)
Thanks! for taking the time to review that. There were 2700 hits on that page already in June and we need it to be.. Right!
fedekrum: I have taken a picture. Find it atached. This is still giving me 0x20.
A quick look at the datasheet for the PCF8574 say...
Slave address pins A2, A1 and A0 are held HIGH or LOW to choose one of eight slave addresses. To conserve power, no internal pull-up resistors are incorporated on A2, A1 or A0, so they must be externally held HIGH or LOW. The address pins (A2, A1, A0) can connect to VDD or VSS directly or through resistors.
So the solder bridges sink the address lines to ground by default (to get address 0x20) maybe what you need to do is find out what side of a bridge goes to GND and then solder a wire from [u]the other side[/u] of the bridge to VCC to see if that changes the address.
maybe what you need to do ...
There doesn't seem to be any 'maybe' involved here. According to the material you quoted you must tie each address line either high or low and not leave any of them floating.
Don
fedekrum, Terry, To help resolve the v3 addressing issue, can you take a close look at your v3 board and its traces and determine what is hooked up to the address lines on the PCF8574. i.e. what is hooked up PCF8574 pins 1,2, and 3.
I'm assuming that the 3 components to the right of the LED are resistors and that they are being used as pull down resistors. And that the solder jumpers are connections to VCC.
It should be easy to tell by closely looking at the board since these boards are simple double sided boards assuming the board isn't already soldered to the LCD. Alternatively you could use an ohm meter.
FYI, the fist thing that I do when I get one of these low cost i2c boards in, is create the schematic from looking at the board. This is crucial to know how to fill in the constructor, how the i2c addressing jumpers and backlight jumpers work.
--- bill
Hi Bill
As I read your post, its obvious to me that you know electronics a hundred thousend times more than me !! ;) Im just a programmer playing with a soldering tool. I will post tomorrow a high detail picture of both sides of the board and if you can and you want, tell me what to sold with what to get a diferent address. thnx
I'm seeing something interesting with this board on a 4x20. A long line wraps around--not to the next line--but to the one following that (line n wraps around to line n+2). And aside from that, it seems to limit the number of characters displayed (from the string) to 63. Is that the way it's supposed to behave? Thanks.
insane: Is that the way it's supposed to behave? Thanks.
http://web.alfredstate.edu/weimandn/lcd/lcd_addressing/lcd_addressing_index.html
Yes, as the link Bill points to explains, writing a long sequence of characters to a 4x20 display will have the characters fill the first line and continue on the third, due to the way the LCD internal addressing works. So this is "normal". You can see this effect with the http://ArduinoInfo.Info example sketches here: http://arduino-info.wikispaces.com/LCD-Blue-I2C
In normal use, you will point the cursor where you want before writing characters, like:
  lcd.setCursor(3,0); //Start at character 4 on line 0
so no real problem...
