I would like to make this project where I use an LED to make it flash at different intervals at each subsequent press of a momentary push button. The goal of this project is to make a safety flasher or as a beacon.
This is how I want it to be.
-first press = led blinks at 1s interval loop
-second press = led blinks at 1/2s interval loop
-third press = led pwm fades in and out at 1s loop
-fourth press = the process resets back to first step
-long press (2s) = Project changes led pin to another one
-long press again = project changes led pin back to original one
So how would the code look like? I figure this has to be done BlinkWIthoutDelay.
/* Blink without Delay
Turns on and off a light emitting diode (LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modified 11 Nov 2013
by Scott Fitzgerald
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number :
const int ledPin = 13; // the number of the LED pin
// Variables will change :
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change :
const long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
This is the code for blink without delay, there is a constant in the code called "interval"
This is the delay between LED changes of state.
You just have to write some code to change the value of "interval" to change the flash rates when you press the button.
First you need to change
to
Gabriel_swe:
Use a counter to keep track of your short presses so you know what mode you have selected.
Depending on your counter you do different things.
That's exactly what I needed!! looks like problem solved.
TomGeorge:
to
