I am pretty new with Arduino and programming in general.
I am playing with files in an SD card, using "SD.h" library. I tried most of the options and made them work correctly in a program. But I have found issues with listing files, and I got stuck.
Find below an example code (the original is embedded in a larger sketch, but this section is the one causing problems):
If I enter the command "dir" for the first time (list all files and folders) it prints all files and directories from my SD card correctly.
But if I enter "dir" again, then it only prints "done!".
Please find below results from the serial monitor when I enter "menu", then when I enter "dir" for the first time, and then when I enter "dir" for the second time:
Menu options:
'menu' - Menu options
'dir' - List files and directories
Command: menu
Menu options:
I have tried using "rewindDirectory()", but I still get some weird behavior:
The first time I enter the "dir" command, I get all the files and folders.
The second time, I only get a few of them.
The third time, I get nothing (only "done!", like when I was not using "rewindDirectory()").
Please find below my modified code and the results in the Serial Monitor:
I guess I am not using "rewindDirectory()" correctly, but I cannot guess what would be the right way. I was looking at SD.h examples and this is how it was used...
As additional info: I tried reducing the number of files and folders in the SD. Using the same sketch, with "rewindDirectory()", now I get the following:
The first time I enter "dir" command: all files and folders are shown correctly.
The second time I enter "dir" command: all files and folders are shown correctly.
The third time, I start loosing some files.
The fourth time, I loose some more files.
The fifth time I get nothing.
Find below results:
Menu options:
IIRC, the SD library can only handle four open files. You may need to close some. To start with, I'd try moving the opening of root to your print directory function. I also wonder if dir.openNextFile consumes one of those four.
I'd rewind at the start of printDirectory unconditionally too.
I think you got it!! Thanks a lot for your help, I would have never found it myself
I did not know that "SD library can only handle four open files". That is a very good point. And I was not realizing that the sketch keeps opening every file, but it never closes any file.
I just entered "entry.close()" at the very end of the "while" funcition.
So everytime I print a file name, I close this file.
It is working good now. I also tried adding a few more files and directories, and it keeps working on and on.
