Edit2: Solved! FastLED was updated with a fix.
Edit: Ohnoes! did i just place my first post in the wrong place?
Hi, when using FastLED 3.1 together with M2TKLIB, i get this error when compiling
In file included from C:\Users\labster\Documents\Arduino\WS2812B_LCD\WS2812B_LCD.ino:1:0:
C:\Users\labster\Documents\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.001
# pragma message "FastLED version 3.001.001"
In file included from C:\Users\labster\Documents\Arduino\libraries\FastLED/FastLED.h:53:0,
C:\Users\labster\Documents\Arduino\libraries\FastLED/fastled_progmem.h:47:57: error: section attribute not allowed for 'm2_rom_void'
#define PROGMEM __attribute__((section(".progmem.data")))
C:\Users\labster\Documents\Arduino\libraries\M2tklib_liquid/utility/m2.h:62:20: note: in expansion of macro 'PROGMEM'
#define M2_PROGMEM PROGMEM
C:\Users\labster\Documents\Arduino\libraries\M2tklib_liquid/utility/m2.h:98:26: note: in expansion of macro 'M2_PROGMEM'
typedef void m2_rom_void M2_PROGMEM;
C:\Users\labster\Documents\Arduino\libraries\FastLED/fastled_progmem.h:47:57: error: section attribute not allowed for 'm2_rom_char'
C:\Users\labster\Documents\Arduino\libraries\M2tklib_liquid/utility/m2.h:99:26: note: in expansion of macro 'M2_PROGMEM'
typedef char m2_rom_char M2_PROGMEM;
exit status 1
Error compiling for board Arduino Nano.
It compiles fine when using FastLED 3.0.3
Anyone had this problem before, or know whats going on?
Here is the code i use to display a scrollable list on a 20x4 lcd, and Serial.print which list item is selected using a 4x1 membrane keypad, the plan is to use this to change FasLED effects, i got something working using Neopixelbus library but my mind was blown when trying to include more effects, sorry if its a unreadable mess,but iam a complete noob and its all a night worth of copypaste
Any help, tips, and ninja-tricks is much appreciated!
//#include <FastLED.h> I get the error when this is uncommented
#include "M2tk.h"
#include "utility/m2ghnlc.h"
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
unsigned long Interval; // milliseconds between updates
unsigned long lastUpdate; // last update of position
// BUTTONS //
uint8_t uiKeySelectPin = 4;
uint8_t uiKeyNextPin = 5;
uint8_t uiKeyPrevPin = 6;
//uint8_t uiKeyUpPin = 7;
// M2TKLIB STUFF //
const char *selected = "Nothing";
const char *el_strlist_getstr(uint8_t idx, uint8_t msg) {
const char *s = "";
if ( idx == 0 )
s = "Apple";
else if ( idx == 1 )
s = "Banana";
else if ( idx == 2 )
s = "Peach";
else if ( idx == 3 )
s = "Pumpkin";
else if ( idx == 4 )
s = "Corn";
if (msg == M2_STRLIST_MSG_GET_STR) {
/* nothing else todo, return the correct string */
} else if ( msg == M2_STRLIST_MSG_SELECT ) {
selected = s;
return s;
uint8_t el_strlist_first = 0;
uint8_t el_strlist_cnt = 5;
M2_STRLIST(el_strlist, "l3w12", &el_strlist_first, &el_strlist_cnt, el_strlist_getstr);
//M2_SPACE(el_space, "w1h1");
M2_VSB(el_strlist_vsb, "l3w1r1", &el_strlist_first, &el_strlist_cnt);
M2_LIST(list_strlist) = { &el_strlist,/* &el_space,*/ &el_strlist_vsb };
M2_HLIST(el_strlist_hlist, NULL, list_strlist);
M2_SPACE(el_vspace, "w1h1");
M2_LABEL(el_label, NULL, "Selected:");
M2_LABELPTR(el_labelptr, NULL, &selected);
M2_LIST(list_label) = { &el_label, &el_labelptr };
M2_HLIST(el_label_hlist, NULL, list_label);
M2_LIST(list) = { &el_strlist_hlist, /*&el_vspace,*/ &el_label_hlist };
M2_VLIST(el_vlist, NULL, list);
M2_ALIGN(top_el, "-1|1W64H64", &el_vlist);
M2tk m2(&top_el, m2_es_arduino, m2_eh_4bs, m2_gh_nlc);
void effectselect()
if ((millis() - lastUpdate) > Interval) // time to update
lastUpdate = millis();
if (selected == "Apple")
Serial.print(selected);
if (selected == "Banana")
if (selected == "Peach")
if (selected == "Pumpkin")
if (selected == "Corn")
m2_SetNewLiquidCrystal(&lcd, 20, 4);
m2.setPin(M2_KEY_SELECT, uiKeySelectPin);
m2.setPin(M2_KEY_NEXT, uiKeyNextPin);
m2.setPin(M2_KEY_PREV, uiKeyPrevPin);
// m2.setPin(M2_KEY_DATA_UP, uiKeyUpPin);
effectselect();
if ( m2.handleKey() )
m2.draw();
m2.checkKey();
