Thank you for the suggestion. I installed it, installed all the libraries I needed, and made sure to add the JSON file but again it did not work. The new error message looks like this:
Arduino: 1.8.19 (Mac OS X), Board: "ESP32S2 Dev Module, Disabled, Disabled, Disabled, Disabled, UART0, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None, Disabled"
/private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/hardware -hardware /Users/juliasteiwer/Library/Arduino15/packages -tools /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/juliasteiwer/Library/Arduino15/packages -built-in-libraries /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/libraries -libraries /Users/juliasteiwer/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32s2:JTAGAdapter=default,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006 -warnings=none -build-cache /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_cache_122304 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.dfu-util.path=/Users/juliasteiwer/Library/Arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/Users/juliasteiwer/Library/Arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mklittlefs.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.esptool_py.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /Users/juliasteiwer/Documents/Arduino/sketch_sep19a/sketch_sep19a.ino
/private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/hardware -hardware /Users/juliasteiwer/Library/Arduino15/packages -tools /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/juliasteiwer/Library/Arduino15/packages -built-in-libraries /private/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/AppTranslocation/5072F954-3BB1-44F7-B9BA-CEFB880309C3/d/Arduino.app/Contents/Java/libraries -libraries /Users/juliasteiwer/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32s2:JTAGAdapter=default,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006 -warnings=none -build-cache /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_cache_122304 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.dfu-util.path=/Users/juliasteiwer/Library/Arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/Users/juliasteiwer/Library/Arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mklittlefs.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.esptool_py.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /Users/juliasteiwer/Documents/Arduino/sketch_sep19a/sketch_sep19a.ino
Using board 'esp32s2' from platform in folder: /Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11
Using core 'esp32' from platform in folder: /Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11
bash -c "[ ! -f \"/Users/juliasteiwer/Documents/Arduino/sketch_sep19a\"/partitions.csv ] || cp -f \"/Users/juliasteiwer/Documents/Arduino/sketch_sep19a\"/partitions.csv \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/partitions.csv"
bash -c "[ -f \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/partitions.csv ] || [ ! -f \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/variants/esp32s2\"/partitions.csv ] || cp \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/variants/esp32s2\"/partitions.csv \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/partitions.csv"
bash -c "[ -f \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/partitions.csv ] || cp \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11\"/tools/partitions/default.csv \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/partitions.csv"
bash -c "[ -f \"/Users/juliasteiwer/Documents/Arduino/sketch_sep19a\"/bootloader.bin ] && cp -f \"/Users/juliasteiwer/Documents/Arduino/sketch_sep19a\"/bootloader.bin \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/sketch_sep19a.ino.bootloader.bin || ( [ -f \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/variants/esp32s2\"/bootloader.bin ] && cp \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/variants/esp32s2\"/bootloader.bin \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/sketch_sep19a.ino.bootloader.bin || \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1\"/esptool --chip esp32s2 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/arduino_build_841006\"/sketch_sep19a.ino.bootloader.bin \"/Users/juliasteiwer/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/tools/sdk/esp32s2\"/bin/bootloader_qio_80m.elf )"
Traceback (most recent call last):
File "esptool/loader.py", line 57, in <module>
File "PyInstaller/loader/pyimod02_importers.py", line 352, in exec_module
File "serial/tools/list_ports.py", line 31, in <module>
File "serial/tools/list_ports_posix.py", line 33, in <module>
File "serial/tools/list_ports_osx.py", line 26, in <module>
File "ctypes/__init__.py", line 7, in <module>
ImportError: dlopen(/var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/_MEIF1nzTl/lib-dynload/_ctypes.cpython-38-darwin.so, 2): Symbol not found: _ffi_closure_alloc
Referenced from: /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/_MEIF1nzTl/lib-dynload/_ctypes.cpython-38-darwin.so (which was built for Mac OS X 10.15)
Expected in: /usr/lib/libffi.dylib
in /var/folders/nv/h2gr6p0s6hd1ccjw7l_tr5ym0000gn/T/_MEIF1nzTl/lib-dynload/_ctypes.cpython-38-darwin.so
During handling of the above exception, another exception occurred:
File "esptool.py", line 31, in <module>
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "esptool/__init__.py", line 41, in <module>
File "esptool/cmds.py", line 14, in <module>
File "esptool/bin_image.py", line 14, in <module>
File "esptool/loader.py", line 62, in <module>
AttributeError: module 'sys' has no attribute 'VERSION'
[20846] Failed to execute script 'esptool' due to unhandled exception!
exit status 1
Fehler beim Kompilieren für das Board ESP32S2 Dev Module.
