Hello. I'm doing a project on a Sipeed Maixduino Board, which has an on-board ESP32-Cam module. Attempting to compile a sketch gives me this error:
myProgram.0:4:10: fatal error: FS.h: No such file or directory
#include "FS.h"
compilation terminated.
Using library Sipeed_OV2640 at version 1.0 in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_OV2640
Using library Camera at version 1.0 in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Camera
Using library Sipeed_ST7789 at version 1.0 in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_ST7789
Using library Adafruit-GFX-Library at version 1.4.8 in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Adafruit-GFX-Library
exit status 1
My attempts to fix it myself:
ARDUINO-ESP32: Downloaded and attempted to install arduino-esp32-master.zip using Add .ZIP Library....
ERROR: Specified folder/zip file does not contain a valid library -
ESP8266FS: Downloaded and attempted to install ESP8266FS-0.3.0.zip.
SEEED_ARDUINO_FS: Downloaded and installed Seeed_Arduino_FS-2.1.1.zip.
ERROR: Installs but does not resolve the "FS.h: No such file or directory" issue
Can someone point me in the right direction?
Thank you.
UPDATE: I at least figured out why it isn't working:
I was using the Maixduino's own example sketch for the SD card (SD_Test.ino) and that sketch doesn't work (!?). It imports FS.h, which doesn't come with the Maixduino software. And I couldn't find a version of FS for Arduino that supports the k210 architecture.
Look at the other Maixduino example sketches that don't use FS to solve your problem.
Also, none of the versions of FS I attempted to install would install to the 'FS' subfolder in the Maixduino's libraries folder (the Maixduino has its own libraries folder, separate from the Arduino IDE's).
By the way, the Seeed Arduino library did install properly to the Arduino's libraries folder but the Maixduino doesn't look there for its imports.
VERBOSE:
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/me/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/me/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/me/Workspace/Arduino/libraries -fqbn=Maixduino:k210:mduino:toolsloc=default,clksrc=400,burn_baudrate=1500000,burn_tool_firmware=mduino -ide-version=10815 -build-path /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185 -warnings=none -build-cache /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_cache_444233 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv64-unknown-elf-gcc.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409 -prefs=runtime.tools.riscv64-unknown-elf-gcc-8.2.0_20190409.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409 -prefs=runtime.tools.kflash.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/kflash/1.0.2 -prefs=runtime.tools.kflash-1.0.2.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/kflash/1.0.2 -verbose /Users/me/Workspace/Arduino/myProgram/myProgram.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/me/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/me/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/me/Workspace/Arduino/libraries -fqbn=Maixduino:k210:mduino:toolsloc=default,clksrc=400,burn_baudrate=1500000,burn_tool_firmware=mduino -ide-version=10815 -build-path /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185 -warnings=none -build-cache /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_cache_444233 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv64-unknown-elf-gcc.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409 -prefs=runtime.tools.riscv64-unknown-elf-gcc-8.2.0_20190409.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409 -prefs=runtime.tools.kflash.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/kflash/1.0.2 -prefs=runtime.tools.kflash-1.0.2.path=/Users/me/Library/Arduino15/packages/Maixduino/tools/kflash/1.0.2 -verbose /Users/me/Workspace/Arduino/myProgram/myProgram.ino
Using board 'mduino' from platform in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11
Using core 'arduino' from platform in folder: /Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11
Detecting libraries used...
/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409/bin/riscv64-unknown-elf-g++ -c -DCONFIG_LOG_ENABLE -DCONFIG_LOG_LEVEL=LOG_INFO -DDEBUG=1 -D__riscv64 -mcmodel=medany -mabi=lp64f -march=rv64imafc -fno-common -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -fno-zero-initialized-in-bss -Os -ggdb -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Werror=frame-larger-than=65536 -Wno-unused-parameter -Wno-sign-compare -Wno-error=missing-braces -Wno-error=return-type -Wno-error=pointer-sign -Wno-missing-braces -Wno-strict-aliasing -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-int-to-pointer-cast -Wno-error=comment -Wno-error=logical-not-parentheses -Wno-error=duplicate-decl-specifier -Wno-error=parentheses -Wno-error=narrowing -Wno-error=unused-value -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/SPI/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/system/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/ -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino//avr -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/hal/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/bsp/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/drivers/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/utils/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/conf -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/portable -std=gnu++17 -g -Wno-error=unused-variable -Wno-error=unused-function -Wno-error=unused-const-variable -w -x c++ -E -CC -DARDUINO=10815 -DF_CPU=400000000L -DBOARD_SIPEED_MAIX_DUINO -DK210 -DARCH=K210 -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/variants/sipeed_maixduino /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185/sketch/myProgram.ino.cpp -o /dev/null
Alternatives for Sipeed_OV2640.h: [Sipeed_OV2640@1.0]
ResolveLibrary(Sipeed_OV2640.h)
-> candidates: [Sipeed_OV2640@1.0]
/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409/bin/riscv64-unknown-elf-g++ -c -DCONFIG_LOG_ENABLE -DCONFIG_LOG_LEVEL=LOG_INFO -DDEBUG=1 -D__riscv64 -mcmodel=medany -mabi=lp64f -march=rv64imafc -fno-common -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -fno-zero-initialized-in-bss -Os -ggdb -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Werror=frame-larger-than=65536 -Wno-unused-parameter -Wno-sign-compare -Wno-error=missing-braces -Wno-error=return-type -Wno-error=pointer-sign -Wno-missing-braces -Wno-strict-aliasing -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-int-to-pointer-cast -Wno-error=comment -Wno-error=logical-not-parentheses -Wno-error=duplicate-decl-specifier -Wno-error=parentheses -Wno-error=narrowing -Wno-error=unused-value -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/SPI/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/system/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/ -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino//avr -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/hal/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/bsp/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/drivers/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/utils/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/conf -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/portable -std=gnu++17 -g -Wno-error=unused-variable -Wno-error=unused-function -Wno-error=unused-const-variable -w -x c++ -E -CC -DARDUINO=10815 -DF_CPU=400000000L -DBOARD_SIPEED_MAIX_DUINO -DK210 -DARCH=K210 -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/variants/sipeed_maixduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_OV2640/src /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185/sketch/myProgram.ino.cpp -o /dev/null
Alternatives for Camera.h: [Camera@1.0]
ResolveLibrary(Camera.h)
-> candidates: [Camera@1.0]
/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409/bin/riscv64-unknown-elf-g++ -c -DCONFIG_LOG_ENABLE -DCONFIG_LOG_LEVEL=LOG_INFO -DDEBUG=1 -D__riscv64 -mcmodel=medany -mabi=lp64f -march=rv64imafc -fno-common -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -fno-zero-initialized-in-bss -Os -ggdb -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Werror=frame-larger-than=65536 -Wno-unused-parameter -Wno-sign-compare -Wno-error=missing-braces -Wno-error=return-type -Wno-error=pointer-sign -Wno-missing-braces -Wno-strict-aliasing -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-int-to-pointer-cast -Wno-error=comment -Wno-error=logical-not-parentheses -Wno-error=duplicate-decl-specifier -Wno-error=parentheses -Wno-error=narrowing -Wno-error=unused-value -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/SPI/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/system/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/ -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino//avr -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/hal/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/bsp/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/drivers/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/utils/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/conf -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/portable -std=gnu++17 -g -Wno-error=unused-variable -Wno-error=unused-function -Wno-error=unused-const-variable -w -x c++ -E -CC -DARDUINO=10815 -DF_CPU=400000000L -DBOARD_SIPEED_MAIX_DUINO -DK210 -DARCH=K210 -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/variants/sipeed_maixduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_OV2640/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Camera/src /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185/sketch/myProgram.ino.cpp -o /dev/null
Alternatives for Sipeed_ST7789.h: [Sipeed_ST7789@1.0]
ResolveLibrary(Sipeed_ST7789.h)
-> candidates: [Sipeed_ST7789@1.0]
/Users/me/meArduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409/bin/riscv64-unknown-elf-g++ -c -DCONFIG_LOG_ENABLE -DCONFIG_LOG_LEVEL=LOG_INFO -DDEBUG=1 -D__riscv64 -mcmodel=medany -mabi=lp64f -march=rv64imafc -fno-common -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -fno-zero-initialized-in-bss -Os -ggdb -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Werror=frame-larger-than=65536 -Wno-unused-parameter -Wno-sign-compare -Wno-error=missing-braces -Wno-error=return-type -Wno-error=pointer-sign -Wno-missing-braces -Wno-strict-aliasing -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-int-to-pointer-cast -Wno-error=comment -Wno-error=logical-not-parentheses -Wno-error=duplicate-decl-specifier -Wno-error=parentheses -Wno-error=narrowing -Wno-error=unused-value -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/SPI/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/system/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/ -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino//avr -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/hal/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/bsp/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/drivers/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/utils/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/conf -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/portable -std=gnu++17 -g -Wno-error=unused-variable -Wno-error=unused-function -Wno-error=unused-const-variable -w -x c++ -E -CC -DARDUINO=10815 -DF_CPU=400000000L -DBOARD_SIPEED_MAIX_DUINO -DK210 -DARCH=K210 -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/variants/sipeed_maixduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_OV2640/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Camera/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_ST7789/src /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185/sketch/myProgram.ino.cpp -o /dev/null
Alternatives for Adafruit_GFX.h: [Adafruit-GFX-Library@1.4.8]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit-GFX-Library@1.4.8]
/Users/me/Library/Arduino15/packages/Maixduino/tools/riscv64-unknown-elf-gcc/8.2.0_20190409/bin/riscv64-unknown-elf-g++ -c -DCONFIG_LOG_ENABLE -DCONFIG_LOG_LEVEL=LOG_INFO -DDEBUG=1 -D__riscv64 -mcmodel=medany -mabi=lp64f -march=rv64imafc -fno-common -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -fno-zero-initialized-in-bss -Os -ggdb -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Werror=frame-larger-than=65536 -Wno-unused-parameter -Wno-sign-compare -Wno-error=missing-braces -Wno-error=return-type -Wno-error=pointer-sign -Wno-missing-braces -Wno-strict-aliasing -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-int-to-pointer-cast -Wno-error=comment -Wno-error=logical-not-parentheses -Wno-error=duplicate-decl-specifier -Wno-error=parentheses -Wno-error=narrowing -Wno-error=unused-value -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/SPI/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/system/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/ -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino//avr -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/hal/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/bsp/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/drivers/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/utils/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/conf -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/include -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino/kendryte-standalone-sdk/lib/freertos/portable -std=gnu++17 -g -Wno-error=unused-variable -Wno-error=unused-function -Wno-error=unused-const-variable -w -x c++ -E -CC -DARDUINO=10815 -DF_CPU=400000000L -DBOARD_SIPEED_MAIX_DUINO -DK210 -DARCH=K210 -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/cores/arduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/variants/sipeed_maixduino -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_OV2640/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Camera/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Sipeed_ST7789/src -I/Users/me/Library/Arduino15/packages/Maixduino/hardware/k210/0.3.11/libraries/Adafruit-GFX-Library /var/folders/px/6rh7x9fd2dvffptjswd3767w0000gn/T/arduino_build_805185/sketch/myProgram.ino.cpp -o /dev/null
Alternatives for FS.h: []
ResolveLibrary(FS.h)
-> candidates: []
myProgram:4:10: fatal error: FS.h: No such file or directory
#include "FS.h"
exit status 1
