Hello,
so for my first project i think the code turned out relatively good, but, I would like to know if there is any possible way to make it run faster, so for example the diplay updates faster.
here is my code:
#include "SSD1306Ascii.h" //include oled libray
#include "SSD1306AsciiAvrI2c.h" //faster AVR i2c library
#include "HX711.h" //HX711 load-cell-amplifier library
#define DOUT 3 //pin on arduino to wich the digital pin of the HX711 amplifier is conected
#define CLK 2 //pin on arduino to wich the clock pin of the HX711 amplifier is conected
HX711 scale(DOUT, CLK);
#define I2C_ADDRESS 0x3C //Defines the i2c adress of the 32x128 oled
SSD1306AsciiAvrI2c oled;
const int led = 9; //led to arduino pin 9
const int buzzer = 5; //buzzer to arduino pin 5
const int buttonPlus = 6; //plus button to arduino pin 6
const int buttonMinus = 7; //minus button to arduino pin 7
const int buttonTare = 8; //tare button to arduino pin 8
int buttonStatePlus = 0; //variable for reading the plus button status
int buttonStateMinus = 0; //variable for reading the minus button status
int buttonStateTare = 0; //variable for reading the tare button status
int threshold = 2 ; //tourqe threshold level (this is set via plus and minus buttons, actual tourqe wanted)
int threshold1 = 1 ; //warnig before tourqe threshold level (this is also set via plus and minus button, beeps one newtonmetre before actual wanted tourqe level)
void setup() { //start of the setup
oled.begin(&Adafruit128x32, I2C_ADDRESS); //starts oled
oled.setFont(Arial14); //sets oled font
oled.set2X(); //zooms the font by a factor of two so that the complete screen is filled
pinMode(led, OUTPUT); //sets the ledpin as an output
pinMode(buzzer, OUTPUT); //sets the buzzerpin as an output
pinMode(buttonPlus, INPUT_PULLUP); //sets the plus button pin as a pulled up input
pinMode(buttonMinus, INPUT_PULLUP); //sets the minus button pin as a pulled up input
pinMode(buttonTare, INPUT_PULLUP); //sets the tare button pin as a pulled up input
tone(buzzer, 1500); //sounds buzzer at 1500HZ until later notone is called
oled.print("Tare"); //displays "Tare" on oled
scale.set_scale(-11450); //this value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(10); //tares the scale with 10 samples (less samples = faster, less acurate and more samples = slower, more acurate)
noTone(buzzer); //notone shuts down the buzzer
oled.clear(); //completly clears the oled
} //end of the setup
void loop() { //start of the loop
//main code start, the faster the better
float tourqe = abs(scale.get_units()); //converts value from HX711 to the float data type, makes negative values positive with abs and stores it
oled.print(tourqe); //displays stored float value from HX711 on oled
oled.print(" Nm ---"); //displays "Nm" after tourqe value
oled.println(); //starts a new line on the oled
if (tourqe < threshold && tourqe > threshold1) { //if tourqe value is between threshold and threshold1
tone(buzzer, 2000, 100); //beeps buzzer at 2000HZ for 100 milliseconds to let you know you are close
} //ends if statement
if (tourqe > threshold) { //if tourqe value is over set threshold
tone(buzzer, 2000, 200); //constanstly sounds buzzer at 2000HZ for 200 milliseconds
digitalWrite(led, HIGH); //turns the led on
else {digitalWrite(led, LOW); //else it turns off the led
//main code end
//this code is only needed when button is pressed
if (digitalRead(buttonPlus) == LOW) { //if plus button is pressed
tone(buzzer, 1500, 25); //sounds the buzzer at 1500HZ for 25 milliseconds
threshold += 1; //adds 1 to the threshold
threshold1 += 1; //adds 1 to the threshold1
digitalWrite(led, LOW); //turns the led off
oled.print(threshold); //displays the now set threshold on the oled
oled.print(" Nm SET ---"); //displays "Nm SET" after the threshold
if (digitalRead(buttonMinus) == LOW) { //if minus button is pressed
threshold -=1; //subtracts 1 from the threshold
threshold1 -=1; //subtracts 1 from the threshold1
if (digitalRead(buttonTare) == LOW) { //if tare button is pressed
tone(buzzer, 1500); //sounds the buzzer constantly at 1500HZ
oled.print("TARE"); //displays "TARE"
//end of butten press code
} //end of the loop
The code basically gets the value from an hx711 board and displays it on an oled and there are 3 buttons one led and a buzzer, a tare button, a plus and minus button wich are setting a threshold at wich the buzzer sounds and a threshold1 at wich the buzzer beeps.
thanks for any advice.
