SOLVED
okay, basically I have a analog temperature sensor I have it attached to my Arduino MEGA 2560 on analog pin A14
if I run the default example code of AnalogReadSerial (of course changing the analog pin)
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A14);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
I get a value of 156 in the Serial monitor. (yes this value changed with temperature as it is suppose to)
when I run this code
sensorValue =map(sensorValue, 0, 1023, 0, 5);
delay(1);
I just get a big fat 0 in the serial monitor.
Can someone tell me what it going on here? I have been staring at this code for quite sometime and it looks good to me.
Thank you for you help.
Also I am using Arduino 1.0.5 it is set for "Arduino mega 2560 or mega ADK"
