[Solved}MAX6959 Keyscan
My problem was that I had bad jumper wire in my breadboard. Once I fixed it the code below works correctly.
I am unable to read the keyscan registers in the MAX6959 Display Driver chip. My sketch follows. The Wire.read() statement always returns the value 0. Where am I going wrong?
#include <Wire.h>
byte debounced;  //Indicates which switches were detected and debounced by the MAX6959
byte pressed;   //Indicates which switches were detected as pressed by the MAX6959
 //Open the serial port
 //Initialize the MAX6959 operating state
 Wire.begin();
 Wire.beginTransmission(0x38);
 Wire.write(0x01); // sets starting address to decode mode register
 Wire.write(0x0F); // reg 0xo1 - enable decode mode for all digits
 Wire.write(0x20); // reg 0x02 - half intensity
 Wire.write(0x03); // reg 0x03 - scan limit 3
 Wire.write(0x03); // reg 0x04 - normal operation
 // Writing to register 0x05 is forbidden so this must be ended here
 Wire.endTransmission();
 Wire.write(0x06); // sets starting address to GPIO register
 Wire.write(0x98); /* reg 0x06 - IRQ/SEG9 is segment driver and
 Input1 and Input2 are set to keyscan */
 //Read the switches connected to the MAX6959 Input1 and Input2 pins
 //Set MAX register address to debounced keys
 Wire.beginTransmission(0x38); //Slave address
 Wire.write(0x08); //Debounced key register address
 //Read starting at the the debounced key register
 Wire.requestFrom(0x38, 4);
 while(Wire.available())
   debounced = Wire.read();
   Serial.println(debounced,BIN);
I looked up the MAX6959. Its an LED display driver.
The MAX6959 is a display driver with keyscan. I am using it to drive 4 seven segment digits and 8 distinct LEDs plus scanning eight switches. I have no problem with the display driver function - works great. But key scanning, no luck.
