[Solved]Measuring time between two sensor data .
I have two variables in my sketch that gives me 2 separate data . like -
lightA = 100 ; lightB = 80;
What i want to do is that , when lighA is 100 it will start counting time (In seconds) and when lightB is 50 it will stop counting and give me the time . I have found a sketch in this forum which works as a stopwatch and provides time in seconds . Here is the code
/*  CrossRoads Time-clock  */
unsigned long previousTime = 0;
byte seconds ;
byte minutes ;
byte hours ;
Serial.begin (9600);
void loop ()
// I  think using microseconds is even more accurate
  if (millis() >= (previousTime))
     previousTime = previousTime + 1000;  // use 100000 for uS
     seconds = seconds +1;
     if (seconds == 60)
        seconds = 0;
        minutes = minutes +1;
     if (minutes == 60)
        minutes = 0;
        hours = hours +1;
     if (hours == 13)
        hours = 1;
  Serial.println(seconds,DEC);
  } // end 1 second
} // end loop
I am using if condition to start the counting . But i am not finding a way to stop counting when lightB = 50;
I am using 123d.circuits.io for practicing . So if anyone needs to see my design i can provide it.
Thanks in advance
Wanting those exact values to trigger events is probably unrealistic. Wanting to record when a reading goes above a threshold, or when a reading goes below a threshold makes sense.
But not one based on reading a sensor.
if(supposedToBeCountingTime && lightB <= 50)
   supposedToBeCounting = false;
if(supposedToBeCounting)
   // do the counting
Bonus points if you can figure out the type for supposedToBeCounting and where it is to be declared, and where it is to be set to true.
