SOLVED - Mega 2560 - "Error compiling for board Arduino..." - R2D2 Project
So, I'm working on an R2D2 project that has run into a snag. When I through all of my test code together to make a full system test sketch I got a compile error. NONE of my other partial test sketches are throwing a compile error. And it's not flagging any of my code.
Thoughts?
Here's the code:
 * Author:
 *         Matt Tucker
 * Date:
 *        27APR2018
 * Description:
 *        The combination of several individual test projects. The following code will test:
 *          4 LEDs, 2 motors, 1 servo, and 1 speaker
 *        The code is to be executed on a Mega 2560 with a motor shield and sensor shield.
 * Notes:
 *        Future iterations will include a Raspberry Pi running a Python script that communicates
 *        with the Mega 2560. The Python script will use OpenCV to evaluate images from a live
 *        video for faces, dogs, ect and then send commands to the Mega 2560 accordingly.
//***Speaker***
#include <SD.h>
#define SDPIN 53
#include <TMRpcm.h>
TMRpcm tmrpcm; // @suppress("Type cannot be resolved")
int i = 1;
String file;
String type = ".wav";
//********END*****//
//***UltraSonic***
const int pingPin=A4;//UltraSonic Sensor Pin. let it be noted that const means constant
//***LEDs***
const int ledPin1 = 34;
const int ledPin2 = 36;
const int ledPin3 = 38;
const int ledPin4 = 40;
//***Motors_Servos***
#include <AFMotor.h>
#include <Servo.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
Servo servo1;
const int INTPOST = servo1.read();
int angle;
//***GeneralGlobalVariables***
long rndNum;
  randomSeed(analogRead(0));
  //***Speaker***
    tmrpcm.speakerPin = 46;
    tmrpcm.setVolume(7);
    if (!SD.begin(SDPIN))
      Serial.println("Initialization Failed!");
      return;
  //***Motors_Servo***
    servo1.attach(9);
    Serial.println("Servo's Recorded Initial Position: " + INTPOST);
    Serial.println("Servo's Current Position: " + servo1.read());
  //***LEDs***
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
  //***StartUP***
  tmrpcm.play("60.wav");
  digitalWrite(ledPin1, HIGH);
  digitalWrite(ledPin2, HIGH);
  digitalWrite(ledPin3, HIGH);
  digitalWrite(ledPin4, HIGH);
  delay(250);
//***Motors***
void Forward()
  motor1.setSpeed(200);
  motor1.run(RELEASE);
  motor2.setSpeed(200);
  motor2.run(RELEASE);
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  delay(2000);
void VearLeft()
  motor2.setSpeed(100);
  delay(2000);
void VearRight()
  motor1.setSpeed(100);
  delay(2000);
void TurnLeft()
  motor2.run(BACKWARD);
  delay(2000);
void TurnRight()
  motor1.run(BACKWARD);
  delay(2000);
void Backward()
  delay(2000);
void RevLeft()
  delay(2000);
void RevRight()
  delay(2000);
void Coast() //No dynamic breaking function, will have to calculate breaking algorithm
  delay(2000);
/***Will calculate this by hand at later date***
void Stop()
//***Servo***
void Servo_Motor_Turn()
  angle = random(1, 90);
  rndNum = random();
  if(rndNum%2 == 1)
    servo1.write(90 - angle);
    servo1.write(90 + angle);
void Servo_Motor_UnTurn()
  servo1.write(INTPOST);
//***UltraSonic***
long Sensor_loop()
  long microseconds, inches;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  microseconds=pulseIn(pingPin, HIGH);
  //code to convert time to distance
  inches= long (microseconds/74/2);
  //code to print distance values
  Serial.print(inches);
  Serial.print("in, ");
  return inches;
  delay(100);
//***LEDs***
void Blink()
  digitalWrite(ledPin2, LOW);
  digitalWrite(ledPin3, LOW);
  rndNum= random(20);
  delay(rndNum*100);
  digitalWrite(ledPin1, LOW);
  rndNum= random(20);
  delay(rndNum*100);
  digitalWrite(ledPin4, LOW);
  rndNum= random(20);
  delay(rndNum*100);
  rndNum= random(20);
  delay(rndNum*100);
  //ALL***UltraSonic_Motors_Servo_Speaker_LEDs***ALL
  long inches = Sensor_loop();
    while(inches>6)
        Forward();
        Blink();
        rndNum= random(20);
        delay(rndNum*100);
    Coast();
    Blink();
    file = String(i%60) + type;
    tmrpcm.play(file.c_str());
    Servo_Motor_Turn();
    Backward();
    delay(2000);
    Coast();
    Blink();
    Servo_Motor_UnTurn();
    delay(2000);
    Blink();
    Blink();
    i++;
Nevermind. Problem solved. I deleted all of the libraries and reinstalled them.
