SOLVED -- Mega 2560 serial communication works but cannot upload sketches (hat tip in0)
Mega gradually stopped uploading by IDE 1.8.19 and IDE 1.8.15. Avrdude complains "not in sync". Symptoms are:
  • avrdude: stk500_recv(): programmer is not responding -- sometimes complains stk500_getsync() attempt 1 of 10: not in sync ... (see below)
  • Arduino IDE 2.0 can upload sketches, but not IDE 1.8.19/ 15
  • three other Megas, two out of the box, display same problem, and will not upload
  • Same problem (programmer not responding, not in sync) trying to upload to an Uno.
  • replaced USB cable
  • Serial Monitor works, and I can send and receive using serial monitor
  • re-installed windows USB driver, and same problem with CH340 Mega boards
  • rebooted Windows 7
  • re-installed IDE 1.8.19
  • board (AVR Mega) and port are all correct - only one port available and says Arduino Mega 2560. IDE 2.0 has no issues uploading.
  • Loopback test is successful
This is really baffling. If the bootloader is broken, why does IDE 2.0 work, and why do the other 3 Megas not upload with IDE 1.18.19?
My theory: IDE 2.0 has hacked the Arduino USB driver to disable IDE 1.8 uploading!!! (just kidding)
I'm pretty noob. Looked but could not find a parallel situation in past comments. Frankly, I am happier with IDE 2.0, except for its Serial Monitor.
C:\Users\Taler\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Taler\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -V -patmega1280 -carduino -PCOM22 -b57600 -D -Uflash:w:C:\Users\Taler\AppData\Local\Temp\arduino_build_371376/Blink.ino.hex:i avrdude: Version 6.3-20190619
System wide configuration file is "C:\Users\Taler\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM20
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x73
avrdude done.  Thank you
An error occurred while uploading the sketch
Go to tools and be sure you have selected the correct board.
SOLVED! Thanks to in0 in another thread, this is a simple case of choosing the wrong 'Processor' for the Mega2560 board. The Mega 2560 board comes in two variety of processors - 1280 and 2560. I had accidentally set the processor to 1280, and this is sticky. Changing it back to 2560 - Tools->Processor->Atmega2560 - made the problem go away.
